Old 03-29-2018, 05:59 AM   #21
2017 27' Flying Cloud
London , Ontario
On my trailer the jack runs via a single positive lead. Does that mean that, because I do not see a negative lead anywhere and therefore cannot attach its negative lead to the shunt, that the power used by the jack will not be tracked by the Victron?
Philip Jones is offline   Reply With Quote
Old 03-29-2018, 06:00 AM   #22
billrector's Avatar
Fort Worth , Texas
I have wondered the same thing!
billrector is offline   Reply With Quote
Old 03-29-2018, 06:05 AM   #23
Overkill Specialist
GMFL's Avatar
2020 30’ Globetrotter
2014 23' International
Dadeville , Alabama
It uses the frame as neg(-). If your shunt is the first thing to touch the neg(-) post of your battery bank you will capture every load on the system including the tongue jack, and phantom things like co/propane detector.
Think of if this way. The frame does not generate power. It gets its Neg(-) from battery. Shunt just has to be first in line.
Old 03-29-2018, 06:07 AM   #24
London , Ontario
Sounds good. Thanks for the explanation.
Old 03-31-2018, 01:29 PM   #25
AirMiles's Avatar
2018 27' Globetrotter
Apollo Beach , Florida
Here is a good article about battery monitoring that I found extremely enlightening. https://marinehowto.com/programming-a-battery-monitor/
2021 Northern-Lite 10-2 & F350 DRW PSD, 600W Solar/Victron/600A BattleBorn
146 nights 31,000 miles (first 10 months!)
Sold: 2018 GT27Q, 74 nights 12,777 miles
Sold: 2017 FC25FB, 316 nights 40,150 miles
Sold: 2013 Casita SD17 89 nights 16,200 miles
AirMiles is offline   Reply With Quote
Old 03-31-2018, 02:47 PM   #26
Adventure.AS's Avatar
2017 25' International
Port Dover , ON Canada
Great article by Rod Collins of "Marine How To". Thanks for sharing.
Ray B.
Adventure.AS is offline   Reply With Quote
Old 05-30-2018, 03:21 PM   #27
wareaglewalt's Avatar
2017 25' Flying Cloud
Bushnell , Florida
I'm running into a similar situation with my BMV712. We have 2-6 volt Trojan AGMs that are brand new. Today it was reading -108 Ah (yeah we haven't had much sun) and 11.89 volts with very minimal load at that point in time. But the SOC was around 62%. What I'm really curious about is what to put in for my full SOC? Victron mentions this might be different since I'm using solar, but any ideas what I should program for Charged Voltage? I'm using 217 Ah for battery capacity. The rest of the settings I left as default.
wareaglewalt is offline   Reply With Quote
Victron 712 install in 27' FB Philip Jones Batteries, Univolts, Converters & Inverters 22 03-18-2018 03:20 PM
Victron BMV-712 install in 2017 30 International dmcgaugh Batteries, Univolts, Converters & Inverters 3 03-09-2018 12:24 AM
Incorrect readings Victron BMV-702 NoResults Batteries, Univolts, Converters & Inverters 1 06-01-2017 03:51 PM
Victron BMV 702 install using solar prewire Brav Batteries, Univolts, Converters & Inverters 4 11-21-2016 01:22 AM
Victron Energy BMV-702 Battery Monitor TinVenture Electrical - Systems, Generators, Batteries & Solar 5 10-15-2016 08:49 AM
