jgbagley, the more reliable way to tell how discharged your batteries are is by installing a Victron battery monitor. This works like a fuel level gauge on your tow vehicle.
As your batteries discharge, a shunt connected between your batteries and the load of your trailer measures the current used. When you recharge with either shore power or solar, the shunt measures the current going back into the batteries. This is the more accurate way to tell when you’ve consumed 50% of your batteries.
Victron now sells a SmartShunt without the display. You can monitor everything via their App using Bluetooth.
I installed a BVM-712 with the display but would have gotten the SmartShunt if it was available at the time. I never look at the display.
I documented the installation on this thread (hot link). Good luck!
Jeff
