Old 09-18-2017, 09:41 PM   #1
2004 16' International CCD
encino , California
possible to run A/C on 2000i, and Inverter
I have a 16 bambi and was going to upgrade battery to a 31 but I saw another bambi with 2 six volt trojans and a 2000w inverter...... its got me wondering if that would power up the A/C simultaneously with 1 honda 2000..... the cost might be nearly the same as me buying another honda 2000 to pair and run the ac....and I wouldn't have to lug a second one with me. I have no idea how to configure the inverter to the A/C unit so that they could work in tandem to get it going...... is there a way to sort of hard wire that inverter into whole trailer so it runs all the 110 plugs and the a/c........I run a 300w inverter now to power the tv but i plug the tv directly into it.
thanks for any help
tim
resedaheat is offline   Reply With Quote
Old 09-18-2017, 10:18 PM   #2
2018 19' Flying Cloud
Newport , Washington
For a lot less money you could simply install an EzStart and run your AC off of your exiting 2000i. No need for another generator or an upgraded inverter.
Dale & Jane
2018 Flying Cloud 19
2003 Dodge Ram 2500 Quad Cab Diesel
KelloggKid is offline   Reply With Quote
Old 09-18-2017, 11:40 PM   #3
The Aluminum Tent 3
pcskier's Avatar
2014 23' Flying Cloud
Park City , Utah
http://www.airforums.com/forums/f37/...rt-167609.html
https://www.microair.net/collections...nt=30176048267
Use "Airstream" at checkout and it might still be $50 off.
As mentioned, you can then run your AC using your 2000w honda, and run AC hooked up to 15 or 20 amp home power source as well.
pcskier is online now   Reply With Quote
Inverter install and wiring run help (2001 Excella) fventura 1997 -2001 Excella 3 09-18-2017 07:31 PM
Inverter install and wiring run help (2001 Excella) fventura Batteries, Univolts, Converters & Inverters 0 07-10-2017 07:58 AM
Honda 2000i vs. Honda 2000i Companion danandmimi Generators & Solar Power 33 09-13-2016 10:21 AM
Honda 2000i companion + 2000i or just 2 2000i's??? socdiva Generators & Solar Power 5 10-27-2009 02:53 PM
