I am also wondering what is normal. My 19' is drawing between .1 and .2 amps in store mode. I have a Trimetric battery monitor which has minimal draw, and probably the propane detector. I don't know what else is on.
Russ
I have about 150mA as a normal parasitic draw when the switch is disconnected. I moved my propane detector so that it is also off. On my unit, the brake actuator board takes a bit and my solar controller are active. Also I was told by Bogart that the Trimetric consumes about 10mA when the display is off.
-Rich-
Thank you everyone for your comments. I am going to be bringing my AS next week to the folks who installed our lithium battery pack and solar panels to take a quick look at what the parasitic draws are.
I will report back on this thread with my findings.
