PD4655 install problem
I installed a PD4655 to use with my new Battleborn Lithium Batteries.
The PD4655 DC Board did not have the same configuration as my WFCO 8955 PEC-J that I was replacing. The WFCO board had two terminals for red wires near the bottom of the board. The PD4655 has only one terminal for red. I put both red wires on the single PD4655 terminal. Doing this seems to work but the battery shutoff doesn't work. I tried each wire separately and the shutoff then worked with one of the wires but it would not charge the batteries.
Would appreciate any info or advice. I currently left both on the single terminal and will rely on a manual battery shutoff. Please see attached pictures.
Thanks in advance for any help.
