Originally Posted by bfdowling
Thanks Bob; I thought as much. Any ideas on a replacement? Am checking with local airstream repair center for a 2000W Victron, if there is such a size; I don’t want to go through the wiring an increase sizing to suit a larger inverter…
Hi
There is a 2,000W Victron. It's almost as expensive as the 3,000W. What pretty much everybody buys are "hybrid" units. You replace both the inverter and the converter / charger with the single unit. Less clutter and you get better charging performance.
The Xantrex stuff seems to work pretty well. They are a bit smaller than the Victron's (and a bit less expensive). Like the Victron the unit to buy is the hybrid version.
With a hybrid, the same cables that power the inverter also charge the battery. That way you can run more charge current than the typical stock wiring permits. As long as you are around 2,000W or less I would *guess* ( = I don't now ) the wires that are there would be adequate. Very much worth checking to be sure ..... At the 3KW level, if you want to actually *use* the 3KW, you would need more wire.
