Old 11-01-2017, 11:54 AM   #1
2017 30' Flying Cloud
Raleigh , North Carolina
Parallax Temp Compensation
I spoke with an engineer at Parallax. Figured why not call them since Airstream uses them as a supplier.
He said that their Temperature Compensation upgrade. $58.00. If you install this unit it will allow the converter to supply 14.4 volts for 4 hours. Every time you plug into shore power will create and event that will boost the battery charger process for 4 hours. He suggested that will greatly increase how much charge you will have on the batteries during a charging cycle.
He suggested that once batteries are fully charged you should place the battery switch to store mode. This will eliminate any over charging of the batteries and reduce the risk of "boiling off the water in the batteries"
The unit has a cable that connects in the controller and a 2nd cable that has to be run to the battery box and attached to the negative terminal of the battery.
I am thinking this might be a cost effective reliable way to get the batteries charged faster after a deep discharge event.
Anybody out there with experience with I the 4400 TAU unit??
jim6090 is offline   Reply With Quote
Old 11-01-2017, 12:44 PM   #2
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
IMHO......another option would be a better converter.
Good Luck
"Any nation that can survive what we have lately in the way of government, is on the high road to permanent glory."
Molly Ivins
"Mary-Jane....'cuz 2020 sucks"
Tahawus
ROBERT CROSS is online now   Reply With Quote
Old 11-01-2017, 02:39 PM   #3
Mattirs's Avatar
2016 25' Flying Cloud
Fairfield , California
Just installed the temp 4400 unit on my 2016 FC, so far it is working great in the driveway. I will be taking her out in January, will find out how it works in the wild.
The install was easy with one hitch. When I am at a desktop and not my phone will give a better answer.
Mattirs is offline   Reply With Quote
Old 11-02-2017, 09:09 AM   #4
Kent , Washington
Please do. I’m interested in this option. Did you buy it from Parallax?
DannyClark is offline   Reply With Quote
Old 11-02-2017, 10:12 AM   #5
Mattirs's Avatar
Found it in a clearance bin at an RV dealership, knew what it was because I was thinking about buying one. Check Amazon. Hopefully I will be on my home computer tonight. I took some photos as I installed it.
Loss-of-use compensation. The Pirate Insurance & Claims 15 04-16-2018 05:44 PM
droopy aluminum step - a kludge compensation until something better can be done. Bob Blarney Steps 21 10-23-2017 09:02 AM
Parallax 8355 Temp Upgrade 4400TAU AirstreamCSH Electrical - Systems, Generators, Batteries & Solar 2 02-25-2017 01:08 PM
Parallax to Intellipower TIMEMACHINE Batteries, Univolts, Converters & Inverters 25 01-08-2008 03:29 PM
Parallax charger with temp control Pacerized Batteries, Univolts, Converters & Inverters 2 04-21-2007 06:16 PM
