You might find the following info to be useful. I cut-n-pasted from my response to another thread on a similar concern ():
Originally Posted by BogeyPro View Post
Hello, everyone. Wondering all you experts out there could take a look at my Orion settings...does something seem amiss or could be adjusted to make it work properly? FYI, I am the OP of this thread, and have the Ford F-150 Powerboost. On my maiden voyage with the Orion installed, it was confirmed to be in Bulk Charge mode. SOC was 62% on departure...on arrival, after 350 miles of driving, SOC was 63%. Huge disappointment. So I am open to any suggestions..THANK YOU!!
Hi BogeyPro.
I had similar experiences with respect to the Victron Orion 12v-12v 18A DC-DC on both my Cayenne and recently on my new 2023 Ford F350.
I documented how I analyzed the situation and came up with some settings that work well in a related thread on airforums. I bet these settings will work much better for you than your current settings. Look through the thread and hunt for the postings by foobar.
Hopefully this link works:
https://www.airforums.com/forums/f44...ed-245081.html
To make it easier on everyone reading this thread, I copied the key contents from the other thread above and include them below.
Begin cut-n-paste from the "other thread":
Here is what my settings are for my 2023 F350 Diesel Lariat with the Lariat Ultimate Package and the Victron Orion-Tr isolating 12v-12v 18A dc-dc charger are. I will try and explain my rationale for the settings as best as I can.
First note: The default values for the "smart alternator" option on the engine start/stop detection settings page simply do not work. You will need to modify these parameter values, which will change the pull down option setting to "user defined" automatically once you change one of the parameters on this settings page.
Let's get started....
The trucks smart alternator appears to output either 13v or 14v based on my limited testing so far.
So I set the start voltage on the engine start/stop detection settings page to 13v.
In case the voltage drops after the truck is started, I set the delayed start value to 12.6v. This was an arbitrary choice on my part as I never saw less than 13v from the output of the smart alternator.
I left the delayed start delay value alone.
The next setting is very important. I set the shutdown voltage to be 8v. It's important that this value is less than the minimum input voltage lockout value. The value here doesn't matter as long as it is less than or equal to the lockout voltage value since the F350 uses a relay to disconnect the 7 pin power from the trucks
12v system when you turn off the ignition.
Why does this value need to be less than the lockout voltage value? I initially had it set to be 13.2v. Then I noticed that the voltage on the input to the dc-dc dropped to 13.2v. Hmm, so I dropped it to 12.5v and then 11.5v. And... Drum roll please... The Orion input voltage dropped to 12.5v and 11.5v respectively AND the DC power entering my battery bank according to my smartshunt and cerbo GX also increased proportionally!!
What was happening is the Orion was essentially cutting off the output current once the input shutdown voltage was reached. If the shutdown voltage value is higher than the minimum lockout voltage OR is higher than the voltage drop induced by the Orion input current, it effectively throttles the Orion output current because the output current shuts off once the Orion input shutdown voltage is reached!. Hopefully this makes sense. So, I figured the best value for the shutdown voltage was a value less than the minimum lockout voltage. This allows the Orion to reach a full 18A output.
As for the input voltage lockout parameter, you want the voltage set to be less than the minimum voltage the Orion will experience when it is producing the maximum output current. Setting this is a trial and error exercise, but low values don't really cause any harm as the potential range of input current is well within the maximum safe joule heating limit for the tow vehicle wiring (this is true for the 18A Orion, but it is probably not true for the 30A Orion).
So, a value of 9v for the input lockout voltage and 8v for the shutdown voltage allowed my Orion to output the maximum wattage into the battery (220w-240w, temperature dependent) via my 2023 Ford F350.
I set the restart value on the lockout voltage page to the minimum voltage the F350 seems to generate in my limited testing so far (i.e. 13v). I might need to tweak this value and the start and delayed voltage parameter values later based on additional observation of the trucks system behavior.
I hope this is accurate and helps others with their setting choices.
I forgot to mention that my voltage at the input of the Orion settled at 10.35v when the F350 voltage was 14v and the Orion output current was at the maximum value. So 3.65v drop along everything feeding the Orion.
End of cut-n-paste from the other thread.
BogeyPro, please try the following settings:
Engine shutdown detection page:
-Use "User defined" settings
- Start Voltage = 13v
- Delayed Start Voltage = 12.6v
- Delayed start voltage delay = 120s
- Shutdown voltage = 8.00v
Input voltage lock-out page:
- Lockout voltage = 9.00v
- Restart value = 13.00v
The settings above allowed my Orion to produce the maximum 18A into my lithium battery bank. And I'll bet these settings will work well on your F150 PowerBoost too as the
12v systems are independent from the PowerBoost architecture and are most likely the same across Fords truck model lineup (F150's and Super Duty trucks).
Last notes: there is still a bit of idiosyncratic behavior that I haven't had a chance to resolve. If my battery bank is fully charged, the Orion won't pull any current from the F350 and the F350 coughs up a warning message when I start the ignition that goes something like: the trailer battery isn't charging or isn't present. If this happens, the F350 doesn't energize the 7 pin power relay and the Orion isn't functional. Other Ford truck owners have reported something similar when then batteries reach a fully charged condition while driving and the Orion stops pulling current from the tow vehicle. The truck will then disable the 7 pin power relay and charging stops (I haven't yet experienced this issue as I haven't had much towing time with the new truck).
