Originally Posted by Pdish24
Where did you place the Multiplus II? Is it a 3000W? Could you upload photos?
I have a Multiplus II 3000W, and hoping to purchase a 27FBT very soon.
I posted a detailed discussion with pictures
here. I installed everything in the front storage compartment. I put together everything on a piece of plywood at home and then lowered it into place from above. My goal was to be able to run all the AC equipment except for AC and hot water heater. This meant creating an AC breaker box in the front area. We are now able to use microwave, hair dryer, etc when dry camping. One change I made later was to change out the 5" Cerbo GX for a 7" Cerbo GX. The print was too small to read for my old eyes.
Small cooling fans were put in the driver side partition of the storage area. When arriving at a camping spot with shore power after several days of dry camping, the Multiplus II heats the compartment up quite rapidly. I have seen it at 105 degrees even with fans running. The Multiplus temperature limit is 150 degrees but that may affect other items in the compartment.
My biggest issue turned out to be the DC-DC charger. That saga is discussed
here. Biggest takeaway is to use 4 AWG wire on both positive and negative sides directly to the battery in the TV.
