Old 02-15-2025, 11:07 AM   #1
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
Odd power converter behavior?
I am all fixed now. New power converter.
Apparently the old power converter was putting out the correct voltage but was not capable of producing much current. The batteries were dead. I checked the PC voltage with a meter and it seemed fine. I replaced the batteries and everything worked fine a few days. And then the batteries started discharging some again. I bought a little digital voltmeter to plug into the 12 volt outlet and the voltage seemed right (about 13.6). But when I turned on a fan or several lights the voltage would drop to 12.5 or so and the batteries would discharge. Turn the fan off and the voltage would soon go back to 13.6. My conclusion was voltage but few amps from the PC?
Old 02-15-2025, 11:37 AM   #2
2025 25' Trade Wind
Beaver Dam , Wisconsin
Please post make and model number of the converter/charger or inverter/charger.
1988 technology was less capable. High current solid state devices were extremely expensive. Your guess is probably correct. The specifications for the converter will confirm if the guess is correct.
12.5 volts on lead acid batteries is near fully charged. This should not cause a problem. However if battery voltage drops below 11.8 volts, it could take many hours, maybe even a day or two to fully recharge.
Paul Bristol - In the wind!
2025 AirStream Trade Wind
2024 Ford Expedition Max LS with factory towing package
PaulBristol is offline   Reply With Quote
Old 02-15-2025, 05:08 PM   #3
1988 25' Excella
1987 32' Excella
The problem power converter was a Boondocker converter that was installed 5 or 6 years ago to replace the original Univolt converter. My point is that I do not think the batteries should discharge enough to notice when plugged in to shore power all the time. The new converter works the way I think it should. I turn on a fan and the voltage does not drop much and the battery does not run down.
Old 02-15-2025, 06:01 PM   #4
1988 32' Excella
Robbinsville , New Jersey
I have seen a couple of times were there was a poor connection, where there was voltage with no or light load then nothing with a heavy load. Of course the bad connection could be inside the old converter and possibly not really repairable.
Old 02-16-2025, 07:10 AM   #5
2025 25' Trade Wind
Thank you for posting the resolution. I am sorry I missed it in your post. I learned to read more carefully.
Old 02-16-2025, 07:16 AM   #6
1988 25' Excella
1987 32' Excella
That certainly seems like what was happening. I suspect the problem was in the converter because the connections to it seemed tight when I took it out and the new one works fine without me checking the rest of the system.
Old 02-16-2025, 08:07 AM   #7
CBWELL's Avatar
2010 30' Classic
Warren , Manitoba
Nothing seems to last as long as the old Univolts! I have replaced a couple of WFCO converters after only a couple of years. My "go to" units are Progressive Dynamics, which seem to stand up a lot longer. It will be interesting to see the life cycle of the new converters with the tremendous increase of electrification in newer trailers and the drastic increase of battery capacity required to run all the electronics in the newer trailers.
ACI #7394
2012 GMC 2500 HD Duramax Denali
2010 Classic Limited 30' ,1994 Excella 34'
1987 Limited 34', 1976 31' Sovereign, 1976 Argosy 22' Gone to new homes
Hensley Hitch
CBWELL is offline   Reply With Quote
Old 02-16-2025, 03:45 PM   #8
2020 25' Flying Cloud
2024 27' Globetrotter
Alexandria , Minnesota
Power Converter Potential Issues
Disappointed with all of the junk left behind from assembly!
Recently accessed the Power Converter on a 2024 Globetrotter FBQ. Large amounts of wood shavings, insulation material and metal bits, all waiting to be sucked through the cooling fan system! Solar controller just thrown on top of the converter. Numerous other locations throughout the trailer with debris just left around. Why wouldn't they vacuum out areas they work on??
cicho69 is offline   Reply With Quote
Old 02-17-2025, 06:54 AM   #9
2017 19' International
Tallahassee , Florida
If I ran Airstream, this — adding a vacuum to every work station —*would be high on my reform list, along with more intelligent wiring.
WhereStream is offline   Reply With Quote
Old 02-17-2025, 07:10 AM   #10
2022 33' Classic
Chesapeake , Virginia
Lol. Wait until you drop the underbelly access panel, or under the freshwater tank. In comparison, we had a Leisure Travel Van (LTV) Unity before the AS. It was spotless in those tucked away recesses. Attention to detail.
BGClassic is offline   Reply With Quote
Old 02-17-2025, 08:35 AM   #11
NO HUMBLE OPINION
ALUMINUMINUM's Avatar
1968 20' Globetrotter
ANN ARBOR , THE GREAT LAKES
Maybe they were napping when yours came through...
ALUMINUMINUM is offline   Reply With Quote
Old 02-18-2025, 08:51 AM   #12
Also had an LTV (Serenity) Very high level of attention to detail and pride in their workmanship. Both Airstreams we owned were fully of debris where assemblers thought nobody would notice. Vacuums at each Airstream workstation would definitely help.
Odd behavior of AC condensation draining Belegedhel Furnaces, Heaters, Fireplaces & Air Conditioning 11 06-24-2016 06:13 AM
PD9260 strange behavior Skater Batteries, Univolts, Converters & Inverters 12 04-13-2012 11:44 PM
Strange Hot Water Behavior Jim Foster Water Heaters, Filters & Pumps 4 05-28-2010 08:43 PM
Strange 12v Behavior in '67 GT tphillips Electrical - Systems, Generators, Batteries & Solar 2 10-08-2009 05:58 PM
Explain this Dump Valve behavior..... Chuck Waste Systems, Tanks & Totes 2 08-28-2003 11:18 AM
