06-17-2025, 09:54 AM
Little Rock
, Arkansas
Not charging
Our 25 foot 2018 International batteries are not charging with ground hook ups or on the road. Any ideas what could cause this?
06-17-2025, 10:11 AM
Keys Dave
2021 25' Flying Cloud
Big Torch Key
, FL
Your going to tell us a lot more about your equipment and situation. Do you have solar, a DC to DC charger, what about your converter. The first thing to check is the breaker.
06-17-2025, 12:01 PM
Little Rock
, Arkansas
Where does the breaker wire connect to the battery? It looks like we have an issue there. We are not using solar.
06-17-2025, 01:04 PM
2022 33' Classic
Chesapeake
, Virginia
If you mean "shore power" when you say ground hookups, then the charging path is from the converter. The converter takes 120VAC shore power and converts to DC, and charges the battery. There should be an AC circuit breaker for the converter, in your load center. Check that first.
While on the road, unless you have a DC-DC converter/charger, you're not putting much charge into the battery from the tow vehicle, via the 7-pin.
06-17-2025, 01:06 PM
2021 30RB Classic
Hinckley
, Ohio
Check the battery for a fuse at the postive terminal.
My budget won't stop me from buying something online that I don't need, but the threat of getting promotional
emails every day for the rest of my life just might!
06-17-2025, 08:59 PM
2017 28' International
Jim Falls
, Wisconsin
When you are on shore power do you have the switch to “in use?” If not the converter will not charge the batteries.
If it is and not charging then as stated above check circuit breaker.
Hopefully not a bad converter.
How old are the batteries?
Here is what AI states on Google:
Airstream batteries not charging on shore power can stem from a few common issues, including faulty connections, blown fuses, or a malfunctioning converter. It's also possible the batteries themselves are the problem, or the converter is not properly regulating the charge.
By the way, I bought a portable jumper for $200 just in case the batteries go down so that I can’t use the power jack. Something you may want to invest in.
Let us know when you get it fixed. Always interested in what the solutions are…
06-17-2025, 11:01 PM
1994 25' Excella
Waukesha
, Wisconsin
Have they ever charged correctly? Is this a new trailer to you? I see that your information states you're 'still looking' so I'm guessing you might have just acquired this trailer.
Some more information about your setup and maybe a few pictures (of the batteries, converter, etc) might help us help you.
So many possibilities that it's really hard to make recommendations just yet.
Richard
11018
1994 Excella 25 'Gertie' Follow the build on Gertie!
1999 Suburban LS 2500 w/7.4L V8 'Bert'
1974 GMC 4108a - Custom Coach Land Cruiser 'The Bus' (Sold)
1994 25' Excella
Waukesha
, Wisconsin
I've found that AI rarely helps provide anything other than overly broad and general answers for things like this.
Richard
11018
06-18-2025, 06:34 AM
2025 25' Trade Wind
Beaver Dam
, Wisconsin
In this case, the AI seems to have covered the issue. More troubleshooting is required to narrow it down.
Entry door switch "ON"
Is there a disconnect switch near the batteries? Is it "ON"?
Converter/charger circuit breaker "ON". Switch it "OFF" then back "ON" to be sure.
Voltmeter:
Check voltage on battery terminals before connecting to shore power.
Check voltage again after plugging in. Voltage should rise slowly to 13.6 or more.
Loose or corroded connections between battery and converter/charger.
Battery fuse blown
Post make and model of converter/charger or inverter/charger for better advice.
Lots of other possibilities.
Paul Bristol - In the wind!
2025 AirStream Trade Wind
2024 Ford Expedition Max LS with factory towing package
06-18-2025, 07:57 AM
2019 28' Flying Cloud
Broward
Your converter may not be working. Converters can get fried if the campground electrical grid is not working properly. The converter converts 110 AC to DC needed for battery charging. First check the circuit breaker to the converter. If that's OK then check the converter output for 12 VDC. First you'll have to find the converter. On my FC28 it's hidden behind the circuit breaker panel below the refrigerator. You'll have to remove the panel to get at the converter. Disconnect the heavy leads to the batteries and check for 12 VDC. If there's nothing there, check your converter manual to see if there's a fuse or anything else you can do. If the converter is bad you can get another one on Amazon for around $100, or you can pick one up at Camping World if there's one nearby.
06-18-2025, 08:32 AM
1994 25' Excella
Waukesha
, Wisconsin
It covered it only in the sense of listing all possible causes without any specifics.
To properly diagnose something like this requires a bit of back and forth to gather enough information, not just throwing out a list of possible causes. That's what I was attempting to do with the few questions I started with.
Richard
11018
06-18-2025, 09:36 AM
Jim Falls
, Wisconsin
Well the possible causes are what someone needs to know. You start then with the simplest and move up. That's how all diagnostics are done. After all we aren't there on the site dealing with the problem. We have no idea what the OP has done or not done. What else are you going to do, but list the possible causes and go from there?
Also this forum isn't like a chat session where we talk to the OP back and forth. We don't know if he's even following this. He may have solved the issue by now. All our advice at this point may be a complete waste of time.
I have also found on this forum that many like to get down deep into the weeds with all kinds of complex answers. Generally most problems are resolved fairly simply. I was a maintenance worker for a number of years while in graduate school. When we had a call for a problem we always started with the simplest solutions. 90% of the time the simple solutions worked, and very rarely was it anything complex.
I don't know how many times I was called by tenants that said their oven wasn't working. I went into the apartment and flipped the breaker. Problem solved. I can only remember 1 time I had to change the oven filament.
06-18-2025, 11:01 AM
1988 32' Excella
Robbinsville
, New Jersey
While that's true, several people have given some "back" and are still waiting for some "forth to gather enough information" so it's possible to do anything other then "just throwing out a list of possible causes."
06-18-2025, 05:44 PM
Little Rock
, Arkansas
I think this has to be my trouble, what does this wire too? Hell I can’t figure out how to attach a photo from my phone!
06-18-2025, 06:20 PM
Little Rock
, Arkansas
not charging
I have been on the road and unable to answer any of the comments. We have had this airstream since new in 2018, My issue is the batteries are stone dead and will not charge on a full day drive or an overnight stay on shore power. I see a wire that has a switch on the end that appears to have have come undone from somewhere. I have taken a picture of the battery box but cannot figure out how to load it on this reply. The batteries are normal batteries that needed changing. I don't want to do that until I figure out why it isn't charging.
06-19-2025, 04:52 AM
Keys Dave
Big Torch Key
, FL
As much as I love this forum posting pictures seems to be more difficult than it needs to be.
Google how to post here, I had to. Once you know how give us some pictures of the problem areas and I am sure people will respond quickly with great help.
06-19-2025, 05:55 AM
2025 25' Trade Wind
Beaver Dam
, Wisconsin
I recommend you get a portable charger and charge up your lead acid batteries. Lead acid batteries do not do well when they spend long periods discharged. A week is okay, more than a month would not be good.
06-19-2025, 08:16 AM
Jim Falls
, Wisconsin
Unattached or loose wire….that would be a problem. No wires in the box should be loose.
I feel your frustration. I know what it’s like. Hopefully you can get a picture uploaded soon.
Here’s a suggestion if you can’t upload the picture to this site. Call an Airstream dealer; maybe where you bought your unit. Send their maintenance people a picture. Maybe they can help you out. Or even take your unit to a local RV dealer, tell them your problem, and see if there is a quick fix.
And I agree withe above post about getting a charger and get those batteries charged. By the way….if those batteries are old you may now need new batteries if they have been discharged a long time.
06-19-2025, 08:44 AM
2015 20' Flying Cloud
Kingsport
, Tennessee
When you start a reply, scroll down under the text box, and there's a "Manage Attachments" button under "Attach Files". That opens up a window where you can attach photos to....
-Leslie
WBCCI #1051
06-19-2025, 07:52 PM
Little Rock
, Arkansas
Yeah, that is above my pay grade. It should be simple, it is almost anywhere else I try. This ask for a URL number.
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Battery not charging, lights not working, 120 works fine
Biker16 |
Electrical - Systems, Generators, Batteries & Solar |
8 |
08-30-2021 05:56 PM |
USB Charging Ports not charging
WkendWarrior |
29 |
09-08-2018 08:12 PM |
Help! Battery not charging, outlets not working when plugged in
AirGal04 |
9 |
06-06-2014 09:15 PM |
Batteries not charging while driving
wildwoodrver |
36 |
08-22-2008 05:33 PM |
OOPS! battery not charging,water hook up spilling into reserve tank?
outerbanksdeb |
Batteries, Univolts, Converters & Inverters |
2 |
08-02-2004 12:40 PM |
