Originally Posted by mcjohn
Hello All,
I’ve got a 2022 Caravel 19cb with the progressive dynamics 1000w inverter that will power on but I don’t have power to either of my two inverter outlets. The panel isn’t showing any errors, I’ve double checked the GFI breaker and the inverter breaker, neither were tripped. I’m at a bit of a loss on what to check next.
Thanks for any insight….
There are likely two 20 amp 120 volt circuit breakers. One goes to the inverter AC input. The other is from the inverter AC 120 volt output. Since the display shows 123 volts AC, the output 20 amp breaker may be tripped. Switch it "OFF" then back "ON" to be sure.
https://www.progressivedyn.com/wp-co...ide-701580.pdf
See page 14 for testing and error codes.
Could be loose or corroded connection at the inverter 120 volt output or anywhere after the output.
Paul Bristol - In the wind!
2025 AirStream Trade Wind
2024 Ford Expedition Max LS with factory towing package
