Old 05-03-2020, 04:14 PM   #1
2019 22' Sport
Wenatchee , Washington
No power from inverter WFCO WF-5110
I have 2018 Classic 30RBT and my inverter is not working. So the fans on the inverter are on and the display shows the correct incoming voltage, outgoing voltage, and amps being drawn. The troubleshooting docs say that if the amber/yellow light is on it should be working but if there is no power replace it. I'm hoping there is something else to try. None of the outlets have any power. It's a WFCO WF-5110 series with the red plastic cover. Thanks for the help.
JasonLaLanne is offline   Reply With Quote
Old 12-16-2023, 05:39 PM   #2
2022 Caravel (sold)
2021 20' Caravel
2015 27' Flying Cloud
Paso Robles , California
Did you ever figure out your inverter problem. We bought a used 2015 27FBQ Fly Cloud and experienced the same problem on our first trip this week
805Vet is offline   Reply With Quote
Old 12-16-2023, 06:24 PM   #3
2022 25' Flying Cloud
Tualatin , Oregon
Do you have the manual? I found a manual that should be similar and shows a circuit breaker on the back side of the unit.
Have you checked that?
https://www.bestconverter.com/assets...110R-Manua.pdf
TitusNW is offline   Reply With Quote
Old 12-17-2023, 01:00 AM   #4
2022 Caravel (sold)
2021 20' Caravel
My problem is (was) intermittent. The inverter is running perfectly (though the fan is bothersome) in the driveway right now. All day in fact.
Earlier this week though .... stayed at a park with high voltage (129VAC). The hardwired surge protector would not allow us to connect to shore power, until the voltage dropped below 128 V. Even then, the pedestal power was 124 VAC. I suspect the converter was over charging the batteries, since the battery voltage was 14.4 VDC, which is much higher than the optimal 13.7 VDC. The excessive battery voltage may have caused the inverter to stumble. The owners manual is not particularly useful, especially the troubleshooting flowchart. Their flowchart said "Replace the inverter"
I called Power Surge to see if there is a way to calibrate the high voltage limit and they said "NO". The engineer suggested buying a Variac or autotransformer to dial the shore power voltage down. We will test my intermittent failure theory once my Variac arrives since I can replicate the overcharge condition.
Old 02-11-2024, 07:33 PM   #5
2022 Caravel (sold)
2021 20' Caravel
So here we are 1 month later. My 20 Amp Variac works well enough since we have no need for the AC or Heat Pump.. I installed a remote monitor screen for our Progressive Industries internal surge protector and saw the device would not power up due top over voltage. The voltage was high (again)! So i plugged in the Variac. I set the Variac to 125V output so the inverter kicks out still as the voltage in the park still bounces around. The Variac seems to work well but it is outside in a plastic box so I need to fab up a better - vented - solution. It will be part of my kit going forward.
WFCO Airstream DC to AC 1 KW Power Inverter RivaHaven Airstream Classifieds 0 12-17-2018 12:15 PM
WFCO WF5110H Inverter - PRICE DROP RivetingTrvl Airstream Classifieds 0 06-21-2015 01:48 PM
WFCO WF5110H Inverter ghaynes755 Airstream Classifieds 0 05-25-2015 08:01 PM
Modification to reduce fan noise for the WFCO 1000 W Inverter alano 2011 - 2015 Classic (all lengths) 8 05-08-2015 02:26 PM
WFCO WF5110H Inverter ghaynes755 Airstream Classifieds 0 07-24-2014 09:28 PM
