Old 03-05-2017, 11:43 AM   #21
2015 30' Classic
Pleasanton , California
No need to worry. The capacity rating on battery chargers has more to do with the worst-case heat sinking capabilities of the charger when used to recharge a battery from a fully depleted condition. You're very close to the rating and your intention is the keep the batteries topped up, so you won't be repeatedly using the charger in it's most demanding mode. If they manual states approximate charge times, connecting the charger to a slightly larger battery might exaggerate these times.
Al, K6IV
2015 30' Classic, "Chez Nu"
2014 RAM 2500 w/Cummins Diesel
ProPride Hitch, 400 W Solar
alano is offline   Reply With Quote
Old 03-05-2017, 01:12 PM   #22
mikeinca's Avatar
2020 25' Globetrotter
Santa Rosa , California
Much appreciated, Al!
mikeinca is offline   Reply With Quote
Old 12-03-2017, 07:00 PM   #23
Kensington , Maryland
I'm using the same setup as the OP (CTEK) to maintain 2 AGM batteries with the coach in "store" mode.
Before I start using this wanted to double check how to hook the CTEK up. I assume I should use attach the CTEK to one pole on different batteries eg "A and B".
A.(Pos)* (Neg)* Battery one
(Pos)* B(Neg)* Battery two
2019 26' U FC RBT "Buck"
Subforum dedicated to Airstreams and riding bicycles:
https://www.velocipedesalon.com/forum/f62/
Too tall is online now   Reply With Quote
USB Charging Ports not charging WkendWarrior Electrical - Systems, Generators, Batteries & Solar 29 09-08-2018 08:12 PM
Newbie Question About Battery Charging Time and Storage jackvosney Batteries, Univolts, Converters & Inverters 0 02-01-2017 11:54 AM
Shore power not charging battery after battery replacement P and Y Batteries, Univolts, Converters & Inverters 15 11-22-2016 08:36 AM
Battery converter not charging battery airstreamz Electrical - Systems, Generators, Batteries & Solar 5 09-24-2014 03:55 PM
Question re: battery charging Lani Batteries, Univolts, Converters & Inverters 11 07-12-2009 10:02 PM
