Old 11-01-2020, 04:27 PM   #1
2015 25' Flying Cloud
Redmond , Washington
New converter -- and now no shore power
Fellow Airstreamers,
This afternoon I went to install a new Progressive Dynamics 4655 in our 2015 Flying Cloud 25FB. Near as I can tell I followed the instructions to the letter. When I went to connect to shore power and test everything out the shore power fuse (not on the AS) instantly tripped. Alarmed, I re-checked my wiring and everything still seemed right to me. Positive to positive and negative to negative all around. I reset the breakers inside the trailer and the one outside as well. Tried it again and it didn't instantly trip, but after about 2 minutes of the converter not turning on there was a loud pop and bright flash from the left side of the converter. No fire or anything like that. Everything in the trailer still works on 12v, but nothing works on shore power.
I've determined one of these things must be the root cause here
1. I wired something wrong
2. I got a faulty converter
If anyone with knowledge about this sort of thing has any insight I'd greatly appreciate it. Photos attached of the new converter installed so you can check my wiring and set up. Thanks for taking the time to help me out!
ID:	382408   Click image for larger version
McStreamy_ is offline   Reply With Quote
Old 11-01-2020, 06:40 PM   #2
Airstream Driver
PeterH-350LE's Avatar
1994 30' Excella
1992 35' Airstream 350
Images: 49
Call Andy at Progressive Dynamic, he will walk you through and determine if it is defective. I had PD9260 that would pop the shore power GFCI, but only when the batteries were low. Eventually I had it replaced under warranty.
Edit: I just looked at your picture and are you sure you connected the DC +/- to 12 v distribution panel and AC to 110 v fuse panel. Looks to me that you reversed it??? Thickness of wires looks wrong. You may have smoked the converter.
1991 300LE Classic Touring Coach
AIR #13
PeterH-350LE is offline   Reply With Quote
Old 11-02-2020, 06:55 AM   #3
Thanks for the reply. I'll give them a call today. I'm going to reach out to Randy over at Best Converter as well.
Dometic refrigerator won’t run on shore power& water heater light on when on shore po fotoman1527 General Repair Forum 23 05-03-2022 05:29 PM
Shore power and gen power not working merrillv Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 5 03-14-2019 09:46 AM
Best way to wire inverter/converter/shore power for seamless AC power justgoclimb Batteries, Univolts, Converters & Inverters 39 06-28-2017 04:51 PM
HELP?! On Shore Power, but lights dim, and power fades TGadaire Batteries, Univolts, Converters & Inverters 4 11-24-2012 05:18 PM
Shore power and battery power problems jfremstad Electrical - Systems, Generators, Batteries & Solar 5 05-03-2007 08:23 AM
