Old 03-08-2020, 12:40 PM   #1
2019 23' International
Portland , Oregon
Need some help here
Just picked up my trailer from storage. Battery read 12.17. Plugged in and now this
Any thoughts?
2019 International Signature 23FB "Cecil"
2020 RAM 1500 Laramie
Former coach: 2015 Bambi 16 "Beanie"
leedav is offline   Reply With Quote
Old 03-08-2020, 12:47 PM   #2
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Not sure but I’m assuming the moment you plug in you’re going to see 100%. Someone more familiar with your system could say for sure. In my older (2012) the analog gauge goes to full whenever I’m plugged in.
Old 03-08-2020, 01:01 PM   #3
Portland , Oregon
Get that. Sorry if I was unclear. It's the 1.2A that's odd. Should be around 20
Old 03-08-2020, 01:57 PM   #4
W , New England
What did you have running at the time? Wondering if the 1.6A is telling you the actual draw, not capacity. If you only had some LED lights on, 1.6A might make sense?
Old 03-08-2020, 02:34 PM   #5
r carl's Avatar
Lin , Ne
It's fully charged. Now it's just trickle charging.
Old 03-08-2020, 03:12 PM   #6
Portland , Oregon
Nothing on
Old 03-08-2020, 03:13 PM   #7
Portland , Oregon
Strange it'd be fully charged after sitting since Xmas
Old 03-08-2020, 03:20 PM   #8
Sag Harbor , New York
That's the understatement of the year IMO.
Is there some factor you are missing?
Does your storage area charge batteries without you knowing it?
Are you sure you understand your monitor fully, and have you read your owner's manual, and any special instruction books which apply to the monitor? The monitor is reading 14.28 volts, and probably reads 100% when you are on shore power, like our older ones, as suggested by SSM.
Lots of possible questions . . .
Good luck,
Peter
PS -- [edit better link] Search results for monitor posts here: https://www.google.com/search?ei=g2J...4dUDCAo&uact=5
PS2 -- Please read your manual(s) and unplug from shore power. Wait a couple of hours, and give us new screen shots of the monitor in various modes [before you plug into shore power again]. Thanks.
Old 03-08-2020, 03:27 PM   #9
2016 19ft flying cloud
Spokane , Washington
alot of things could be drawing down battery
Lights,inverter( even when off),carbon Mon detectors, fantastic fan sensors, tv ant amp,fridg (if on)radio,bass extension booster
Also let it set a couple hrs before reading voltages after charging to get true reading ,,,
Spinonedad is offline   Reply With Quote
Old 03-08-2020, 03:35 PM   #10
Portland , Oregon
That's the thing. I understand this stuff really well. There's no power at my storage place, there's no solar. The disconnect was disconnected. Drew the same amount of current connected to the tow vehicle as it did on shore power. I measured the current at the shunt and it was exactly the same. The only possible conclusion I can get to is the battery stayed full or there's some weird resistance somewhere in the battery or the terminals. at 100% the Progressive Dynamics converter should not have been delivering over 14 volts. Oddly the dongle on the converter didn't respond to my pushing the buttons either. Right now I have shore power disconnected and I'm running all the lights and the fans. later tonight I'll see what the state of charges and see if it takes the appropriate amount of current. If not I'm completely flummoxed
The monitor is reading 14.28 volts. The monitor probably reads 100% when you are on shore power., like our older ones, as suggested by SSM.
Good luck,
Peter
PS -- Search results for monitor posts here: https://www.google.com/search?q=Smar...=airforums.com
Old 03-08-2020, 03:40 PM   #11
Thanks for the update. As requested in my PS2, which did not make it into your quote, please take monitor screen shots in various modes at least 2 hours after unplugging from shore power, and before you plug back in.
There is an explanation IMO.
Check the various threads in my PS search results [as just edited that link was bad]. There are some real battery/monitor experts here, but as should be obvious, I ain't won fo dem.
Old 03-09-2020, 03:22 PM   #12
Portland , Oregon
Anyway ran all the lights until evening. Plugged in and got the right amperage. Left battery is fully charged and the hydrometer reads 0. Right battery reads good. Left tested fine at Interstate, so I'm gonna punt for now.
Old 03-09-2020, 05:28 PM   #13
Thanks for the "gonna punt" update.
Happy trails!
Peter
Need Some help here.....Camping Next weekend? Bryan Rose On The Road... 11 06-11-2007 08:18 AM
new here would like some help shane Member Introductions 3 05-13-2006 07:28 AM
Begging for some help here with power converter sunshine sam Vintage Kin 8 09-29-2005 08:19 AM
