Old 05-28-2018, 03:27 PM   #1
marter's Avatar
2008 19' International
Lincoln , Nebraska
Need a bigger inverter in 19' International
Hello,
We have a 2008 International 19' Airstream with a 600 watt (WF-600T) inverter. I'd like to upgrade it to 1,000 watts but can't find one that will fit in the space occupied by the 600 WFCO inverter without some changes. Maybe I just have to bite the bullet and move some stuff around, but it's pretty tight now.
Has anyone mounted a 1000 watt inverter in the same spot (road side front corner under the dinette seat) as the original 600w? If so, what brand and model? BTW, it's to the right in the picture.
Any other options for locations? I don't think I want it exposed under the dinette table.
Thanks in advance,
Mike
Mike (W9LG) and Jennifer
2008 International 19' Ocean Breeze, Equal-i-zer WDH
2015 Ford F150 4x4 Lariat SuperCrew EcoBoost, 3.55, Max Tow
marter is offline   Reply With Quote
Old 05-28-2018, 10:10 PM   #2
2016 19' Flying Cloud
Portland , Oregon
The Xantrax proWatt 1000 is about the same size of the WFCO one, a little under 12" x 8" x 4"
Snowy is offline   Reply With Quote
Old 05-28-2018, 10:38 PM   #3
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
What the hell is that rats nest? Is that the factory wiring job? Shameful! I would have that cleaned up before sticking something else in that mess.
Neatness counts and costs nothing but a slice of time!
Awful
Old 05-28-2018, 10:56 PM   #4
Living Riveted since 2013
Rocinante's Avatar
2016 Interstate Lounge Ext
Green Cove Springs , Florida
Originally Posted by AtomicNo13 View Post
What...is that rats nest? Is that the factory wiring job? Shameful! I would have that cleaned up before sticking something else in that mess.
Awful
Looks fairly typical of what comes out of the factory, so I’d say, “Yes.”
Have you looked at the factory-installed wiring in your own trailer?
Old 05-28-2018, 11:45 PM   #5
2007 22' International CCD
(Grin) I’m afraid to. It would trigger my ‘neatness’ OCD for sure...then I’d spend forever sorting it out...
Old 05-29-2018, 05:09 AM   #6
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Awful
Translation...the factory makes no changes and the customer makes all the improvements. 😟
Tahawus
"It is more wiser to ponder all things with diligent suspicion, than follow with blind assumption."
RLC
Old 05-29-2018, 05:22 AM   #7
Bruce B's Avatar
2021 25' Globetrotter
Jamestown , Rhode Island
Yes Airstream factory wiring is shameful! We too had the 600 watt factory installed inverter in our 16’ Bambi. It failed and the larger 1000 watt unit was swapped. It really did not fit and it was not big enough for our needs so in the end I just installed my own. By the way, the wiring to the battery to power the inverter is at best sized for a 600 watt unit. The larger inverter will need a wiring upgrade.
Here is a picture of my final inverter “upgrade”. It is a 2000 watt unit that will actually power a coffee maker!
The next picture is of a heater control board I just wired on our boat. The heater installation took about 3 weeks to finish and I am proud and delighted with the results... Airstream should take note of what wiring should look like...
Bruce
ID:	312353   Click image for larger version
Loving our 2021 Globetrotter 25 shopping for the next tow vehicle and 2020 GMC 2500 Sierra Denali Duramax.
Bruce B is offline   Reply With Quote
Old 05-29-2018, 10:21 AM   #8
gr.austin's Avatar
2009 27' FB Classic
Sioux Falls , South Dakota
Good wiring counts
Thank you for doing such a great job wiring your 16 and boat. I am not the only one that appreciates a job well done. I hope you also included wire labels along with a wiring diagram for that next time you need to do some maintenance or repairs. It pays off many times when you have forgotten what you did 3 years ago. Thanks for posting what a finished job should look like. Keep up the good work...
Happy Streaming
gr.austin is offline   Reply With Quote
Old 05-29-2018, 10:22 AM   #9
journeydog's Avatar
2018 28' Tommy Bahama
Silver City , New Mexico
Thank you Bob and Bruce! Before I retired, I worked in the spacecraft world. If I allowed wiring like that I could have been retired earlier. YIKES!!
Class A Safari Trek 2830 - SOLD; TC Lance 1010 - SOLD;
TT Arctic Fox 30U - SOLD; TT Forest River Mini - SOLD;
Class B+ Pleasure Way P
ursuit - FS; $$$$ - GONE
If it ain't broke I can break it
A dime still makes a pretty good screwdriver
journeydog is offline   Reply With Quote
Old 05-29-2018, 11:56 AM   #10
banderabob's Avatar
2008 19' Bambi
2012 23' Flying Cloud
2016 25' Flying Cloud
Bandera , Texas
Can’t help with the space problem, but a heads-up. I recently replaced the 600 with a 1000 watt inverter (from AS) on our 23D. A 1000 watt unit still won’t run very much, such as very small space heaters, or a single serve Keurig, or a hair dryer.
banderabob is offline   Reply With Quote
Old 05-29-2018, 05:43 PM   #11
marter's Avatar
Lincoln , Nebraska
Awful
Shameful? It's either the factory or the previous owner. I won't take credit for it; I've had the trailer 5 weeks. I've upgraded the converter/charger last weekend and felt like I did a reasonable job of wiring (pic below), but I'm just a beginner here trying to learn how to improve my new (to me) trailer. I haven't "stuck something else in that mess" yet, but plan to do some rearranging when I upgrade the inverter and solar controller.
Thanks for the help.
Mike
BTW, if you think that's a rat's nest, you haven't looked behind the Sony head unit in the locker above the dinette. Ask wulfraat.
Old 05-29-2018, 05:45 PM   #12
marter's Avatar
Lincoln , Nebraska
Snowy, thanks for the pointer; I'll take a look at it. I've been looking at the Victron Phoenix inverters; seem to be small enough and a reputable company. Any thoughts on those?
Mike
Old 05-29-2018, 05:48 PM   #13
marter's Avatar
Lincoln , Nebraska
Funny you should mention the Keurig; that's the main driver here for me here. We bought a Keurig mini and it's listed as drawing 700 watts. Are you saying it won't run it, or won't run much other than those listed?
Mike
Old 05-29-2018, 06:01 PM   #14
marter's Avatar
Lincoln , Nebraska
<snip>
Bruce
Bruce,
Thanks for the heads up on the wiring; once I chose and inverter I was going to check that. My inverter is in front near the batteries so shouldn't have a lot of drop. Not sure what's there now. Like I said, just diving into this.
Mike
Old 05-30-2018, 07:40 AM   #15
banderabob's Avatar
2008 19' Bambi
Bandera , Texas
It would not run our single serve Keurig, we ended up purchasing a “Chulux “ brand single serve on Amazon, which works fine and actually takes up less space. Works with all K cups.
Old 05-30-2018, 07:59 AM   #16
banderabob's Avatar
2008 19' Bambi
Bandera , Texas
Mike
It wouldn’t run our single serve Keurig which drew over 1000 watts (I wasn’t smart enough to check this before spending the $$ on the 1000 watt inverter). We bought a “Chulux” brand coffee maker on Amazon that works just fine with all K cups. Haven’t yet found a small space heater that draws under 1000 that I consider to be constructed safe enough.
Old 05-30-2018, 10:19 AM   #17
Rocinante's Avatar
I'm thinking it's probably simpler to just run the propane heat than it would be to try to run an AC-powered electric space heater off the batteries, no matter how big your inverter is. (We have a 3,000 watt inverter and 400 AH of batteries, but even so we would not run a space heater off those batteries.)
Old 05-30-2018, 03:56 PM   #18
marter's Avatar
Lincoln , Nebraska
Well now I can't find where I read the Keurig K-Mini draws 700 watts. Could have sworn that, but when I look on the bottom it says 1425 watts. Hmm. I'll check out the Chulux. Or maybe figure out a different to brew coffee. We love French press coffee but it isn't as quick and easy as the Keurig.
Thanks for the heads up. And for a space heater we're looking at a catalytic space heater, not electric.
Thanks again,
Mike
Old 05-31-2018, 08:19 AM   #19
Rocinante's Avatar
The French Press won’t fill the world with little plastic cups that last for millennia after only one use of each cup.
C’mon, folks, get a grip. Why destroy the world you’re trying to enjoy, when it’s so easy to get far better coffee in an abundance of other ways? French press. Aeropress. Percolator. Chemex. Bialetti. Pour-over. The list of other, far better, and less destructive ways to make coffee in your trailer is quite long. Nearly every one takes up less room in your Airstream than a Keurig, and not one of them needs an inverter.
Old 05-31-2018, 09:40 AM   #20
Not only that, but you have to drink what the little plastic cup makes.
I prefer a little more control...👍
Keurig is for the waiting room.😂
Tahawus
RLC
Do I need a bigger WD hitch? Hopeful1 Towing, Tow Vehicles & Hitches 17 05-01-2017 06:36 AM
Original batteries toast need bigger battery box atheness Electrical - Systems, Generators, Batteries & Solar 3 09-28-2015 10:43 PM
Most likely selling our AS, need something bigger ... advice? stefario Off Topic Forum 12 07-09-2012 09:04 PM
Big Job turned into bigger JOB, need advice. lebolewis Waste Systems, Tanks & Totes 10 11-16-2006 05:28 AM
Bigger (ahem) Toilet? 3Ms75Argosy Sinks, Showers & Toilets 1 09-15-2002 12:09 PM
