Originally Posted by stgerdonly
I need to move the Univolt and battery to make way for a comfortable sleeper sofa. I want to move them to each side of the sofa where the arms are. Can I just extend wiring and is everything connected inside the fuse panel? Help from anyone who has done such a move is appreciated.
Could you provide some pictures and/or a diagram to show the change you want to make? Where are the battery and charger located now and where do you propose putting them. If you truly have a Univolt charger/battery eliminator, this will be the time to replace it with a modern three or four stage unit.
