Old 12-01-2021, 09:24 PM   #1
2016 23' International
Los Altos , California
moving batteries and installing Victron inverter-charger under front bed
Hi all,
I just purchased a used 2016 23FB international and going to add 4 battleborn batteries under front bed along with a 3k victron inverter-charger. I understand how to wire based on lots of research and youtube videos, but can't seem to figure out how to get the shorepower wiring from the old converter location to the new inverter-charger under bed, and the other wiring that needs to run back to the AC-DC panel in kitchen from new inverter-charger.
I'm guessing I will need to go under the coach to run wires since i'm not taking floor out.
Has anyone done this and if, so any pics, suggestions ...
THanks
jsmall01 is offline   Reply With Quote
Old 12-01-2021, 10:34 PM   #2
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
My 50amp AC wires are run inside the trailer with some custom flashing to cover it up along the floor / bedroom wall.
wulfraat is offline   Reply With Quote
Old 12-02-2021, 09:48 AM   #3
That looks clean! What material did you use?
Old 12-02-2021, 05:59 PM   #4
wulfraat's Avatar
My installer Lew Farber did the work. It’s aluminum to match the skin.
Old 12-02-2021, 06:19 PM   #5
Colossus's Avatar
2022 30' Flying Cloud
2018 27' Tommy Bahama
Peachtree City , Georgia
Agreed! That’s a very neat and clean installation!
Colossus is offline   Reply With Quote
Old 12-02-2021, 09:19 PM   #6
yes, very nice. I may still have go under the camper to run my wires.. layout is a bit different on a 23fb
Old 03-15-2022, 01:44 PM   #7
Secaucus , New Jersey
I am trying to do the same on my 23 FBQ and trying to figure out how to link the left with the right set of wires in the battery box. (R/B)
What did you end up doing?
TLBNJ27 is offline   Reply With Quote
Old 03-19-2022, 05:19 PM   #8
2018 27' Flying Cloud
Atlanta , Georgia
I recently finished a lithium upgrade with Multiplus II. I put all equipment in front compartment with two 270 Battleborn batteries under the front bed. I installed AC breaker box in the front compartment with 3 cables under belly pan to kitchen breaker box.
I put 2 AC units and hot water heater on AC out 2 from Multiplus which is only live when on shore power. All other AC circuits ran off inverter which is AC out 1. The third cable was to run shore power up to the new AC breaker box in front compartment.
Details are here: https://www.airforums.com/forums/f44...ud-231684.html
jnm30327 is offline   Reply With Quote
Victron Multiplus Inverter/Charger in 16' Bambi/Caravel SurfnSoCal Electrical - Systems, Generators, Batteries & Solar 3 05-21-2020 02:52 PM
Is anyone using a Victron Charger (not solar or inverter) Omnial Generators & Solar Power 11 09-21-2019 05:59 PM
2 AGM Batteries, Victron 100/30 and 1500 Watt Vertamax Pure Sine Inverter under Dinet JMB11 Batteries, Univolts, Converters & Inverters 0 02-28-2019 04:14 PM
Magnum vs Victron inverter/charger fran&frank Electrical - Systems, Generators, Batteries & Solar 7 12-29-2017 04:52 PM
Victron Multiplus Hybrid/Boosting Inverter/Charger Install CA_Tallguy Electrical - Systems, Generators, Batteries & Solar 7 03-15-2016 11:03 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
