Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Batteries, Univolts, Converters & Inverters
Old 01-26-2021, 04:18 PM   #1
2012 31' Classic
Denver , CO
Mix lead acid batteries and LiFe batteries. Possible?
Is it possible to add LiFe batteries interior to AS and still keep Lead acid batteries in exterior compartments
MJobin is offline   Reply With Quote
Old 01-26-2021, 06:45 PM   #2
DaveP's Avatar
2004 28' Classic
Monument , Colorado
No. That is not possible/good idea. They charge properly at different voltages. The lithiums will also rob all the energy out of your LA batteries as they have very low internal resistance.
DaveP
2004 Airstream Classic 28 "Willard"
2023 Ram 3500 4x4
DaveP is offline   Reply With Quote
Old 01-26-2021, 07:07 PM   #3
Overkill Specialist
GMFL's Avatar
2020 30’ Globetrotter
2014 23' International
Dadeville , Alabama
NO! The nominal voltage of the two battery types are not the same nor are their charging profiles/needs
Instagram @Airstream_Nuts_And_Bolts
DoItYourselfRV Articles
Certified Victron Installer
Old 01-26-2021, 07:12 PM   #4
waninae39's Avatar
2022 25' Flying Cloud
NCR , Ontario
BAD IDEA
different chemistry
different voltages
different charging methods
waninae39 is offline   Reply With Quote
Old 01-26-2021, 10:49 PM   #5
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
Yes! I did it!
Well, kinda [emoji4]
I added lithium under the rear bed in my 30’ (about 275lbs of gear total) and left the lead acid batteries in the tongue-mounted battery compartment..... fully disconnected.... for ballast / tongue weight purposes [emoji4]
After 3 years sitting there I think they register a healthy 4 or 5 volts or something like that haha.
wulfraat is offline   Reply With Quote
Old 01-27-2021, 02:12 AM   #6
2019 30' Flying Cloud
Grass Lake , Michigan
The one way you could do it is by keeping them electrically separated from each other. Separate chargers, powering separate loads and have NO means to interconnect them, ever. That would really complicate the electrical system in your trailer, so the question is why go to all that trouble? If you really NEED the added capacity, just add one more Li battery to your upgrade.
I just upgraded to LFP batteries and simply sold off the 3-year old lead-acid ones on Craigslist. There's a buyer for almost anything out there. I even sold a used marine toilet one time... so many responses, I could have sold a dozen of them.
oldenavy is offline   Reply With Quote
Equalizing Lead Acid Batteries DaveP Batteries, Univolts, Converters & Inverters 20 11-23-2020 08:06 AM
Costco or Interstate 12 volt lead acid Batts? LAWBC Batteries, Univolts, Converters & Inverters 6 04-08-2019 10:37 AM
Universal Power Group 45978 Sealed Lead Acid Battery SagStream Batteries, Univolts, Converters & Inverters 4 04-26-2016 06:40 PM
Maintenance Free Lead-Acid Battery Leak Starstream Batteries, Univolts, Converters & Inverters 15 02-22-2016 10:34 AM
Acid wash or no acid wash? alan.aliciac 1959-69 Tradewind 10 09-04-2015 10:12 PM
