Old 10-13-2023, 12:03 AM   #1
1987 32.5' Airstream 325
Windsor , Ontario
Main power not working
I have a 1987 325 Motorhome. When I recently plugged the unit into the house power I am getting no power to the unit. When I trip the main breaker, nothing happens. Did a continuity check, using a light bulb/two wires, on the breaker. Seems to be no power coming to the breaker(if Iím doing it correctly). One wire on the white, one wire to the black inputs. Tried to the main bus as well.
I have a reel on this unit that gathers the power cord. Wondering if that part of the system has failed. I do not own a multimeter or know how to read one but maybe itís time I did.
Thanks in advance,
Chris
realpank is offline   Reply With Quote
Old 10-13-2023, 07:18 AM   #2
jdalrymple's Avatar
2009 27' FB Flying Cloud
1982 31' International
1991 35' Airstream 350
Jay , Oklahoma
Could be the reel, or the transfer switch between the generator and shore line.
The transfer switch is in the generator position be default. Does the generator run? Does the coach have power when the generator is running?
Regards.
JD
Jeff & Cindy
'09 27FB Flying Cloud;'82 31 International
'91 350 LE MH; '21 Interstate 24GT
Old 10-13-2023, 07:44 AM   #3
2022 20' Caravel
2019 Interstate Lounge Ext
Noblesville , Indiana
Thanks in advance,
Chris
Troubleshooting isn't always finding what's broke but eliminating everything that isn't broke.
vanderwielen is offline   Reply With Quote
Old 10-13-2023, 09:40 AM   #4
Windsor , Ontario
Regards.
JD
Thanks Jeff,
The generator has been problematic and currently does not run. I had it to a repair guy who fiddled with the choke and it fired right up. I rarely use it but do test it once in a while. Last test it did not fire.
Where is the transfer switch?
Old 10-13-2023, 10:27 AM   #5
Half a Rivet Short
2022 Interstate 24X
Carlisle , Pennsylvania
Hi
First off, poking around 120V power can be dangerous. You can get injured. You also can do damage to things. Please study up on how to do this stuff safely.
A wiring diagram is going to be pretty important for tracking this sort of thing down. If you don't already have one, it's best to get one now. You may spend a bit of "quality time" figuring out how to read it. AS has a somewhat "unique" way of doing these drawings.
Once you know what you are looking for from the wiring diagram, it's time to go find everything. The diagrams are sort of a combo of parts location and parts interconnect. Unfortunately they come up a bit short on the "location" part of that. A lot of look here / look there / dig into this is going to be involved.
Now toss in the basic fact that it has been a *lot* of years since the factory built this beast. It may have been this way or that back in 1987. Unless you have owned it the entire time and nobody else has worked on it .... who knows what somebody might have "improved" over the years.
Thus the next step is a "verify everything" sort of pass. You know what might be there from the wiring diagram. It gets compared to what *is* there in real life. Fun things like a hard wired EMS or autotransformer might have been dropped in. The transfer switch that once was over here may have been moved over there. (sometimes they live with the generator .... sometimes not).
With anything like this, take your phone along. Take lots of pictures as you dig here and dig there.
Basic approach:
Start at the wall plug, make sure it has power.
Find the coach end of the power cord, check it for power
Track down the next step (likely the transfer switch), check for power there
You already know there's no power at the breakers.
That sounds easy, it is more involved than it sounds. It's a weekend's worth of effort to find everything and make sure there are no "extra" items along the way.
Stay safe !!!!
Old 10-13-2023, 12:23 PM   #6
Windsor , Ontario
Ok, I did manage to start the generator and all electrical systems are functioning.
Old 10-13-2023, 07:35 PM   #7
Windsor , Ontario
I opened the junction box past the take up reel and there is power going into it so it is not the reel. Thinking the breaker has failed.
Old 12-03-2023, 10:15 AM   #8
Windsor , Ontario
I have traced my power to the transfer switch and it appeared that it was not engaging(I pushed in the spring manually and the power came on)so, I got a new transfer switch, installed to specifications and this did not work. I have also replaced my d-link GFI breaker as a tab was broken and was not sitting securely.
When I plugged in shore power I heard a ďrumbleĒ sound from the rear of the coach and then it tripped my breaker in the house. I thought it might be my water pump engaging but I canít tell by myself.
Puzzled as to where to go next. Has this happened to anyone here? Appreciate any responses in advance.
Chris
Old 12-04-2023, 07:43 AM   #9
Half a Rivet Short
2022 Interstate 24X
Chris
Hi
It's not quite clear if you have shore power to the breaker panel in the RV. If that's still an issue, the transfer switch and the wires from it to the box are what to check.
Assuming you *do* have power to the breakers in the RV:
Best guess: Something didn't quite get done right with the breaker or the transfer switch. That's only a guess. I'd check them first. ("Rumble in the rear" would be the generator on our van).
Is the house circuit big enough to run the A/C? Is the A/C on? Would be my next guess.
Assuming those things aren't it, what to do:
Turn off all the breakers in the RV (including the main).
Hook up shore power
See if the breaker in the house trips. If it does you have a problem ahead of the panel. If not, leave it on and proceed.
Flip on the RV main breaker (but none of the others). If the house breaker trips, you have a problem in the box.
Cycle (turn on, wait a minute, turn off) each individual RV breaker in the box. If the house breaker trips when any one of them is cycled, you have a problem on that circuit.
Fun
Old 12-06-2023, 10:19 AM   #10
Windsor , Ontario
Thanks Bob,
I have an electrician coming by this weekend to check on what i did wrong.
To clarify: my rumble is more like a loud hum(of which I’ve not heard before), the air conditioner switch is off so they cannot come on.
Will be sure to mention your recommendations tho.
Chris
Old 12-09-2023, 09:38 PM   #11
Windsor , Ontario
Good call Bob,
I was just a matter of switching some wires around.
Good feeling not having to take this in to the auto electrician.
Looking forward to first foray in May.
Cheers, Chris
Old 12-10-2023, 07:41 AM   #12
Half a Rivet Short
2022 Interstate 24X
Hi
In a lot of cases "call in a pro" is a really good idea. We each have a skill set. What's easy for one is a challenge for another. That's true of all of us (myself very much included).
Glad you got it fixed !!!!
Fridge not working, freezer is working kswelsh Refrigerators 5 08-03-2023 07:40 PM
Front interior light not working, middle and rear working? jonnyo Lights - Interior & Exterior 5 01-06-2020 12:25 PM
Shore power and gen power not working merrillv Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 5 03-14-2019 10:46 AM
Electic Jack not working - fuse good - manual not working ryandanz Jacks, Stabilizers, Lifting and Leveling 20 04-24-2016 11:04 AM
Dash Air Fan, Power window and Power Seat Stopped working alvinator Land Yacht/Legacy Motorhomes 3 07-13-2014 10:22 AM
