Old 06-09-2024, 12:46 PM   #1
2020 Globetrotter 25 FBT
GettinAway's Avatar
2020 25' Globetrotter
Wildwood , Missouri
Lithium appears not to be charging
I had my 2020 25 GT twin switched over to lithium three years ago. I have two BB 100 ah batteries. I accidentally left the cutoff switch connected. The batteries continued to drain from the propane monitor etc.. When I came up to the farm today to check on things and get my mowing done. I checked the Victron Connect app. It didn’t even find my batteries. So, I was guessing 100% depleted. I plugged the trailer into 30 amp hookup on the barn, and left to mow. Three hours later I open the app and it shows no charge. The percent charge is still dashes.
I thought the batteries would not be harmed by discharging them. I thought there was a built in protection program. I may be wrong. When entering the trailer, I can hear the fan in the converter/inverter running, which usually means the batteries are charging. However it looks like nothing is charged.
Any suggestions? Ronnie Dennis did the install. I will reach out to him if needed. I’m just wondering if anyone has any suggestions.
Jeff
2020 25GT FBT
2012 Toyota Tundra Dbl Cab, 5.7 4x4
Previous AS trailers: (04) 19’ Bambi, and (11) FC 23FB
GettinAway is offline   Reply With Quote
Old 06-09-2024, 01:03 PM   #2
JeffKim's Avatar
2023 25' Globetrotter
2021 16' Bambi
Forest Lake , Minnesota
It's likely they shut down with low-voltage disconnect. Here's a link to the BB revival page. You will need a charger that has the capability to wake up discharged lithium batteries or maybe more easily jumper to a car battery (as described). I have a 5A Victron charger that's very handy in general that has this capability.
2023 Globetrotter 25FBT "Curly"
2017 Audi Q7 3.0T
WBCCI 6343
JeffKim is online now   Reply With Quote
Old 06-09-2024, 03:15 PM   #3
GettinAway's Avatar
Wildwood , Missouri
Thank you! I’ll follow the link, and directions.
2020 25GT FBT
Old 06-09-2024, 03:54 PM   #4
GettinAway's Avatar
Wildwood , Missouri
Well crap. I’m home, the trailer is still at the farm. I leave for Alaska on Tuesday. Gone for a month. I’ll have to figure something out. I left it plugged in to the 30 amp. I’m guessing that wasn’t a good idea either. This could turn ut to be an expensive lesson.
2020 25GT FBT
Old 06-10-2024, 09:03 AM   #5
JeffKim's Avatar
2021 16' Bambi
Are you taking the trailer to Alaska? Otherwise, I don't see any problem leaving it plugged in and reviving the batteries when you get back.
2017 Audi Q7 3.0T
WBCCI 6343
Old 06-10-2024, 09:09 AM   #6
GettinAway's Avatar
Wildwood , Missouri
Well, I actually have another 12,000 mile motorcycle trip planned. Going up the Dempster Highway, instead of the Dalton. So, I’m not taking the AS. Even though my motorcycle would make a fine TV.
Great news though!! The BB are at 100%!!!! I came up this morning to try and save those batteries. The revival protocol mentioned that leaving them fully depleted could be bad for them, and would void the warranty. So, I drove up. Found out they kicked in on their own, and accepted a full charge!
Now back home to get ready to leave at o-dark thirty tomorrow morning.
Thanks again for the help. I never would have seen that revival protocol.
2020 25GT FBT
Old 06-10-2024, 12:24 PM   #7
MMCMRET's Avatar
2021 25' Flying Cloud
Fredericktown , Ohio
Good Response
Very good research and advice.
Todd Mizer
2021 25' FBT Flying Cloud
Ford F-250 6.7L
WBCCI #6826
We have Year-Round Courtesy Parking.
MMCMRET is offline   Reply With Quote
Old 06-10-2024, 12:37 PM   #8
JeffKim's Avatar
2021 16' Bambi
Wow! That sounds like a great adventure. Yes, a great TV but don't ignite controversy and endless debate on what WD hitch to get.
Glad that it worked out and glad I was a help.
2017 Audi Q7 3.0T
WBCCI 6343
Old 06-10-2024, 01:36 PM   #9
GettinAway's Avatar
Wildwood , Missouri
Ha! Hopefully over here in the battery zone, it may not be seen.
I’m still amazed those batteries got out of that dead state, and accepted a charge. Another plus for BB lithium. I woke up at 3:00 am and started imagining everything. Ruined batteries were the best outcome from my imagination. After fires, and ruined electrical systems. I almost left at 3:00.
Getting ready..
2020 25GT FBT
Old 06-10-2024, 02:48 PM   #10
JeffKim's Avatar
2021 16' Bambi
Do you have a Victron solar controller? I just read that the Victron solar controller will attempt to revive a battery if it detects a low voltage.
2017 Audi Q7 3.0T
WBCCI 6343
Old 06-10-2024, 03:39 PM   #11
GettinAway's Avatar
Wildwood , Missouri
I don’t think so, but I really can’t remember what Ronnie put in there. The reason I doubt it is because all I have for solar is a 200w portable. Nothing on the roof. Ronnie did install a new inverter to match up with and charge the lithium batteries. I just don’t recall what he installed.
Here’s what I saw this morning after I disconnected from the 30 amp. This is before I turned the disconnect to off. (Not the AS disconnect, but an inline one that was installed.
2020 25GT FBT
Old 06-11-2024, 06:24 AM   #12
Half a Rivet Short
2022 Interstate 24X
Carlisle , Pennsylvania
Hi
If you look at the very first screenshot…. The batteries are at 13.64V and charging at a 30 amp rate. They likely pulled more current at a lower voltage. You are past 50% charge but probably below 75% at that point.
You have no percentage on the display because the smart shunt shut down. It needs to synchronize. This happens when you get to about 14.4V ( it depends on your settings).
Old 06-11-2024, 08:01 AM   #13
JeffKim's Avatar
2021 16' Bambi
Hi
Ah! I'm all wet. I looked at that and thought it was some other draw, but now it makes sense.
2017 Audi Q7 3.0T
WBCCI 6343
Old 06-12-2024, 05:37 AM   #14
GettinAway's Avatar
Wildwood , Missouri
Hi
Wow! I wish I knew more about this stuff. It’s my fault for not taking the time to learn about it. Lesson learned. Thank you! I was in full panic mode for nothing..
2020 25GT FBT
Old 06-16-2024, 10:25 PM   #15
2022 25' International
San Jose , CA
Lithium 67% state of charge but only 10.4 volts
Hello,
Here's my situation:
2022 International 25' FB. (50A with two AC units, irrelevant while boondocking). 1000W inverter factory installed. Came with two panels, dealer installed two more panels, 380W total and replaced AGM batteries with two 120Ah Expion 360 Lithium batteries. 240Ah total. I installed the smartshunt IP65.
We go boondocking monthly, 2 or 3 nights, in the woods for the past two years. Each trip, the state of charge per the VictronConnect app has dropped at most to like 88% at night and would come back to a ~100% state of charge by the end of the next day. Never had a low voltage issue. This past week, boondocking for 7 days, all the same for the first 4 days, trailer in full sun in the afternoons. Night 4, voltage drops to 10.4, fridge, etc turns off, state of charge at 67%. The remaining days, state of charge would get up to 68% and voltage only up to 11.09. Fridge, etc still not working and again voltage drops to 10.4V at night. The MPPT showed the steady blue light on 'bulk', no other error lights at any time on the MPPT controller. Only have the fridge and the water pump on. Minimal use of the LED lights inside. No radio. No hot water heater and no furnace.
Used the inverter only the first few days for like 3 hours to charge the kid's computer, but those days the state of charge would go back to ~100% and back up to 13V.
Any ideas on what broke?
DanMechanic is offline   Reply With Quote
Old 06-17-2024, 09:32 AM   #16
JeffKim's Avatar
2021 16' Bambi
Originally Posted by DanMechanic View Post
Hello,
Just a hunch, but easy to check. On the shunt there is a setting under Battery settings called "Battery SOC on reset". It should be set to "Keep SOC" not "Set to 100%". On our Bambi in 2022 I installed the shunt and "Set to 100%" was the default and it would reset to 100% for "events" (still not sure what those are) and I was perplexed until someone pointed this out. With our new 2023 GT when I installed the shunt the default was set to "Keep SOC", so could be you have an older version and it's resetting but you are not recharging fully.
Otherwise, no clue. The shunt should be accurate (you can disconnect it and measure the battery voltages), so it's the SOC measure that's wrong.
2017 Audi Q7 3.0T
WBCCI 6343
Old 06-17-2024, 11:10 PM   #17
San Jose , CA
Voltage drop to 10.4V
Hello Jeff, thanks for the response. I just changed that shunt battery setting to 'Keep SOC' per your advise. That setting is different from what the dealer recommended, pls see screen shot attached of what they confirmed for battery settings. They did say to change my discharge floor setting from 5% to their recommended 15%. ( I changed it to 10%...)
However, to me, that drop to 10.4V while the battery was still showing 67% SOC doesn't make sense. Pls see attached generic Lithium battery table SOC vs Volts. Dropping below 12V doesn't occur until SOC is less than 10%. It's not clear to me that the SOC was at 67%, and there was only 10.4V. The factory installed indicator inside the RV also showed the same 10.4V, same as the Victron shunt app.
Additional info: After the drive home, the Victron app shows the batteries at
100% SOC and 13.67V. And the indicator inside also shows the same 13.6V.
And what do you mean by 'events' ?
Thanks.
Name:	Shunt settings.jpg
ID:	444440   Click image for larger version
Name:	SOC vs V.jpg
Old 06-18-2024, 06:45 AM   #18
Half a Rivet Short
2022 Interstate 24X
Hi
The "event" that sets the shunt to 100% is getting above the "fully charged" voltage setting. If that voltage is set correctly ( above 14V ) then indeed the LiFePO4 battery *is* fully charged when you get to that point.
If you run "keep the SOC" the tiny errors that the device inevitably makes all add up and keep adding up forever and ever. That's not ideal.
Also under settings, you have battery capacity. If you have two 100AH batteries, you set it to 200AH. Thus when you get to about 60% you have used almost 100AH.
Now, if one battery goes "off line" you only have 100AH total. The shunt has no clue this has happened. It happily does the math against the 200AH number. You get to 10V and the shunt shows 60% .... sounds like the OP's issue ....
Old 06-18-2024, 09:40 AM   #19
JeffKim's Avatar
2021 16' Bambi
Hi
Thanks, however I'm still confused. Bulk charging is 14.4V, and it will exceed that threshold before the battery is fully charged. The float is 13.6V when fully charged. I periodically will resync the 100% SOC after we've plugged in for a day or so and I'm pretty sure the batteries are fully charged.
Anyways, to clear this up I thought maybe taking the radical step of reading the manual. My new understanding is that the reset to 100% is a function of three parameters: the Charged Voltage, Tail Current, and Charged Detection Time. So, for lithium batteries something like 13.6V is Charge Voltage and the other two parameters are confusing. Tail Current is a percentage (4% default) but it doesn't really say of what, I'm guessing maximum current? Charge Detection Time is the time both Charged Voltage is greater than it's setting (?) and Tail Current is less than it's setting (?). So, for example if these conditions are met for 3 minutes or longer then the battery is considered fully charged. This requires some more googling.
So... IDK, I can see towing with the solar controller doing the charging it will exceed 14.4V or 13.6V but if there's shade or low sun the current will drop and if it's using the charger current as a baseline then it's going to be pretty low percentage anyways and it will reset. That seems like an issue. I have a DC-DC charger also, which muddies the water more (or maybe it's more consistent and makes it clearer). So, I can see with one charging source there's some set of parameters that could work, but it seems a little iffy. I'm sticking with the manual sync method for now.
2017 Audi Q7 3.0T
WBCCI 6343
Old 06-18-2024, 09:55 AM   #20
JeffKim's Avatar
2021 16' Bambi
Thanks.
My understanding is you can set the discharge floor to whatever you want. At 10% it will calculate the SOC based on 90% of the batteries. So, you're seeing what's left of the 90%. It's like setting where the "E" is on your gas tank, most cars have something in reserve when it hits empty. I have ours set on 1%, so it's pretty close to what's available without totally draining the batteries.
My guess is that you were accumulating errors. It would reset to 100% when only partially charged then after some discharge it would charge a little and reset to 100%, so gradually you went to zero even though it said 67%. That was the problem I was seeing with my first experience with the shunt.
I don't know Expion batteries, but they should be able to tell you the settings for both the charger and the shunt. It looks like they are a Victron dealer too, so they better have some idea. Their customer service would probably know better than the dealer.
2017 Audi Q7 3.0T
WBCCI 6343
“E1” code appears on hot water heater panel Spaggs Water Heaters, Filters & Pumps 2 04-28-2023 02:45 PM
Another 1952 Cruisette appears Cruisette52 1951 - 1956 Cruisette 8 04-29-2019 05:33 PM
Leak appears when trailer rear jacked up HCR Fresh Water Systems 20 04-06-2011 04:50 PM
Door lock appears to be broken and locked from inside too! LucyPepper Doors & Locks 12 10-12-2009 10:20 PM
11-20-2008 Airstream appears on CBS's "Eleventh Hour" PeeWee Airstream "In the News" 0 11-20-2008 10:25 PM
