Hello all,
We took the plunge and installed two 100Ah Battle-Born Lithium Iron Phosphate (LifePO4) batteries and the Progressive Dynamics 60Amp LiFePO4 Converter a few weeks ago and I found an extra white wire (negative) that I assume JC capped off (see Old Converter Connection Pic) the last time we were there for warranty work. It lands on the negative side in the main electrical box. The white wire that was connected appears to go directly to the
12v junction box that is tucked away under front compartment and would take a huge effort to access. Looking at the schematic, the white wire should go from the converter to the main electrical box. Any thoughts?
Cheers,
Larry
2019 Classic 33'
2018 F250 Limited
ProPride 3P Hitch
