03-31-2018, 10:46 AM
#21
2017 27' Flying Cloud
Chillicothe
, Ohio
Originally Posted by wulfraat
I went without a tray in my 2008 since they were a snug fit.
While the batteries are you, I’d recommend that you spray down the interior of the battery box with some semi-gloss black rustolium paint for measure.
I was thinking along the same lines. Thanks
04-01-2018, 01:19 PM
#22
Registered User
2016 25' Flying Cloud
Fairfield
Originally Posted by Cispook
Nice day finally - changing terminals etc for the battery install. Pulled the old battery tray out and lots of moisture under same. Going to dry it out good before placing new batteries in the box.
Q: should I put in a generic type tray or go without; I know my new 27T will not fit in the current battery tray that held the Interstates.
I have a FC 2017 model. Someone has a photo to share with the newer battery boxes it would be appreciated.
Regards
FWIW, somewhere I saw it recommended just putting a thin sheet of plexiglass under the batteries. Easier to sacrifice that rather than the bottom of your battery cabinet?
04-01-2018, 01:57 PM
#23
Chillicothe
, Ohio
I used a small battery pad I had laying around
04-01-2018, 02:01 PM
#24
Chillicothe
, Ohio
Final install minus the hook up to the terminals. Going to cut a piece of 1/4 lexicon as a stabilizer between the wing nut and the batteries. Snug fit with batteries placed sideways in the box. Very little wiggle room.
04-08-2018, 07:54 PM
#25
2018 25' Flying Cloud
Hillsboro
, Oregon
Attachment 307620
Why did you choose the 12V Lifeline's over the 6V's?
Thanks!
Jason
04-09-2018, 06:22 AM
#26
Chillicothe
, Ohio
Thanks!
Jason
We boondock on an infrequent basis. Maybe 21 days or so a year. We also knew we would be using a generator to recharge as needed ... so discussing and going back and forth with experts such as Lewster the consensus was I would benefit the most from the AGM 12v set up.
04-09-2018, 09:30 AM
#27
Hillsboro
, Oregon
Thank you for the information! What advantages do the 12V have over the 6V in your situation?
04-10-2018, 11:06 AM
#28
Chillicothe
, Ohio
Lifeline GPL 27-T Batteries
No need to rewire the box for 6A. That about covers it
05-03-2020, 05:00 AM
#29
2018 30' Classic
New Park
, Pennsylvania
AGM battery replacement
Our 2018 30’ Classic is new to us but very lightly used.
We finally had a chance to set it up in our yard to practice “faux” boondocking. Since this is the very first time it has been unplugged in 6 months of our ownership the batteries were barely 9.1v and the solar was not enough to keep anything running. Batteries seemed okay when plugged into 50 AMP and when hooked to the Honda 7000 generator but very weak. It barely kept the Firefly screen lit.
Just because the AS is new to us, batteries are dated 4/17 original and we have no idea how the batteries were maintained by the previous owner...we want to replace them with a new pair.
What is the best replacement battery for our AS (with factory solar) without battery box modifications. We will split our time between boondocking and shore power camping.
I have always been a fan of Interstate but Lifeline looks interesting and well.
Suggestions?
What if...we got it right this time?
Tanner the tin tube
05-03-2020, 05:31 AM
#30
2012 25' FB International
Trent Woods
, North Carolina
Lifeline has always been the gold standard for AGM batteries. Not to say there are not good, cheaper brands. Before I switched to Lithium, I always used Lifelines, Airstream and sailboat.
Larry
05-03-2020, 05:55 AM
#31
2018 30' Classic
New Park
, Pennsylvania
Thanks Larry.
Looks like Lifeline AGM-27T would be a “plug and play” fit.
Amazon $358
Batteryguys $ 329
InvertersRus $ 313
Sound about right?
At double the cost of Interstate batteries they must be good.
Not complaining...Things need to work to make travels enjoyable.
Tanner the tin tube
05-03-2020, 05:59 AM
#32
Trent Woods
, North Carolina
Yep, sounds about right. Like I said...many other brands of AGM's out there. When I was offshore relying on batteries, I knew I could count on Lifelines. Sort of the same sentiment boondocking.
Larry
05-03-2020, 07:00 AM
#33
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
They lasted 11 Seasons in "Cloudsplitter", now in the basement as backup for the sump pump.👍
BTW....the strap is to help lift them over that PITA door hinge...they are heavy buggers.🥴
05-03-2020, 07:39 AM
#34
Rivets?
1992 29' Excella
2010 22' Interstate
Van By The River
, Georgia
We purchased ours from Powerstride Battery. $328 each includes shipping. The batteries were drop-shipped directly from Lifeline.
Lucius and Danielle
1992 29' Excella Classic / 2010 Interstate
2005 Chevrolet Suburban K2500 8.1L
2018 GMC Sierra K1500 SLT, 6.2L, Max Trailering
Got a cooped-up feeling, gotta get out of town, got those Airstream campin' blues...
05-03-2020, 10:53 AM
#35
2018 30' Classic
New Park
, Pennsylvania
What option do you use to attach the solar being there are only two post on a Lifeline GPL-27T?
Tanner the tin tube
05-03-2020, 11:26 AM
#36
2002 25' Safari
Dewey
I installed a lifeline Grp27 in a vintage trailer and when I sold it 12 years later, the battery was still working great. If you want to get long life out of a good battery, replace the converter with a multi stage unit. I am a big fan of Progressive Dynamics converters.
Richard
05-11-2020, 04:08 PM
#37
2018 30' Classic
New Park
, Pennsylvania
We received the new batteries on Saturday from InvertersRUS.
Installed them on the coldest day in May...in PA...ever. Day time high was 46 degrees with a ferocious wind. But it was worth it. The old batteries were toast. The new ones arrived charged at 12.9. Now staying at 13.6 plugged in.
They were pretty much plug and play. We took good pictures before taking the old batteries out. Painted the box, touched up a few rusty spots and cut a battery mat. Other then the weight at 65lbs a battery, the install went fine.
We have been keeping the heat on as we have been having record low temperatures after de-winterizing the AS two weeks ago. The heat has been toasty and the new batteries have kept the inverter fan more quiet...not cycling as often.
I guess we get to test the AC by the end of the week...81 degrees predicted.
We are happy...and still no place to go. Looking at backyard camping for now.
Tanner the tin tube
