Old 08-30-2020, 09:00 PM   #1
2020 20' Bambi
Clayton , North Carolina
Lifeline AGM SOC without a BMV-712 Smart
Hi folks, I did upgrade the Atkinson charge controller in my 2020 Bambi 20í to a Victron 100/30 MPPT when I added more roof solar. With the Atkinson I had a galley readout that would tell me state of charge and I could see in the morning I still had about 70-75%. Seems with the VictronConnect app (and no BMV-712 Smart which is project for 2021) I cannot actually see SOC as a simple readout. Is there a rule of thumb regarding battery voltage reading versus SOC? I do have the Lifeline AGM data sheets but the indo sheet uses open circuit voltage for aged batteries.
Thanks, Stephen
smsasf is offline   Reply With Quote
Old 08-30-2020, 09:47 PM   #2
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
From the lifeline manual..... using open circuit voltage to approximate state of charge...
http://lifelinebatteries.com/wp-cont...cal-Manual.pdf
With house loads on the battery itís nearly impossible to know what the resting voltage is when you quickly peaking at the sea level battery voltage display.... Just know that it can easily read 0.1 - 0.2 volts lower than resting if you have some lower draw house loads applied.
Without a shunt your are only guessing unless you physically disconnect the batts for a few hours and read OCV.
wulfraat is offline   Reply With Quote
Victron BMV-712 Smart w/ AS AGM batteries kittmaster Electrical - Systems, Generators, Batteries & Solar 14 08-23-2022 08:11 AM
Going to JC, need a part ASAP. BMV-712 smart kittmaster General Repair Forum 5 07-20-2020 03:58 PM
Victron BMV-712 Smart Battery Monitor Install&Review lzhome Generators & Solar Power 0 10-03-2019 06:05 AM
Sync settings for Lithium battteries - BMV-712 Smart waninae39 Generators & Solar Power 0 03-30-2018 01:58 PM
Victron BMV-712 install in 2017 30 International dmcgaugh Batteries, Univolts, Converters & Inverters 3 03-09-2018 01:24 AM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
