Originally Posted by AWCHIEF
Charles, does your univolt like the one in the pictures I posted? There really does not seem to be any standard unit that was used. Airstream just seemed to use whatever was on the shelf that day.
That part was called a "Univolt" as it was Airstreams first venture into using something for low voltage other than the battery.
It's really nothing more than a "transformer" with a dual voltage output.
It provides a
12 volt and 19 volt AC output.
The
12 volt output is used for the lights.
The 19 volt output is used for the ceiling fans.
The ceiling fans are
12 volt DC motors, that work perfectly on 19 volts AC.
The 19 volts AC effective DC equivalent is 19 X .70711 which is 13.44 volts.
Replacing that transformer with a true Univolt is very easy. Simply connect all the output wires to the Univolt, making sure that you create separate circuits.
