The ONLY place I would connect an inverter is directly to the battery posts or to a set of dedicated lugs that come directly from the battery posts. Calculate the maximum amp draw from the inverter spec sheet and add a fuse to the positive lead for circuit protection. Anything else is a possible disaster in the making, unless you're using one of those small types that plug in to a 12VDC power socket (like a cigarette lighter plug). They are rated for 15 amps MAX. and won't power much.
lewster
