Old 12-18-2018, 08:47 AM   #1
Tamaroak
2019 25' Flying Cloud
Stillwater , Minnesota
Inverter power for fridge while underway
I own a trawler and will buy an Airstream this year, probably a 25 Flying Cloud. I wonder why I couldn’t install an A/B switch for fridge power that would allow me to choose between shore power at the pedestal and 110v from the inverter, to be used while towing. I think that if this option would be selected while the engine is off it could switch to propane. But would this work?
Tamaroak is offline   Reply With Quote
Old 12-18-2018, 09:05 AM   #2
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 194
Inverter Power for Fridge while Towing
Greetings Tamaroak!
Welcome to the Forums and the world of Airstreaming!
What you propose is possible, but you might try what I do with my Overlander -- turn off the valves on your propane tanks while traveling thus eliminating the possibility that the refrigerator might automatically switch to the propane setting. When I had the restoration work done on my Overlander, I chose a Dometic 3-way refrigerator so rather than utilizing my Inverter to convert 12-vot DC to 120-volt AC, I just turn off the Inverter and gas supply when traveling and the refrigerator auto-selects 12-volt DC. The limiting factor is the battery capacity available in your coach in relation to the draw of the refrigerator. My Overlander has three large AGM RV/Marine batteries and three roof-mounted solar panels and I have never experienced a shortage of 12-volt DC power when traveling with my refrigerator operating on 12-volt DC.
Good luck with your investigation!
Kevin
Kevin D. Allen
WBCCI (Lifetime Member)/VAC #7864
AIR #827
1964 Overlander International
Old 12-18-2018, 02:09 PM   #3
Tamaroak
But our fridge in the 25RB doesn’t have a 12v option, only 110v and propane.
Old 12-18-2018, 02:26 PM   #4
DKB_SATX's Avatar
Alamo Heights , Texas
I think the heating element the larger 2-door Dometics in our modern trailers use is the 325W one.
So, the input you need is 325W, which would equate to about 26A at 12.7V. However, the inverter isn't 100% efficient... WFCO claims 86% efficiency, so now you need about 30A at 12V. It's unlikely that your vehicle will be able to consistently deliver close to that on an extended basis without some modification. If you're not supplying that, your batteries are good for perhaps a couple of hours at that discharge rate.
The propane system, however, draws very little current to keep the valve open and ignite the burner.
— David
Old 12-18-2018, 02:59 PM   #5
Sag Harbor , New York
Plenty of folks tow their Airstreams with the fridge running on propane and 12 volt control system. Just turn it off when fueling near a gas pump.
https://www.google.com/search?q=Frid...com&gws_rd=ssl
Keep It Simple, Stu.
Old 12-18-2018, 03:07 PM   #6
2007 22' International CCD
Yup. That discussion has been beat to death (multiple times). I just make sure the fridge doors are well clear of the gas pump, and otherwise leave the propane on while I'm on the road. It's a non-issue unless I'm heading for a tunnel that's posted as requiring propane to be turned off while in the tunnel...and that's an East Coast thing, IIRC.
Gasoline fumes tend to be heavier than air anyway...and modern pumps recycle the vapors, or simply burn them off after collecting them in a controlled manner...
Old 12-19-2018, 10:23 AM   #7
To OP: Based on this thread so far, it appears your options are (in no particular order):
1. Sell the boat; Buy the Airstream.
2. Replace the fridge with one that supports 12v.
3. Always run the fridge on propane.
4. Try your idea, but heed DKB_SATX's warnings.
Personally, I'd choose #1, but I'm admittedly biased. [emoji55]
Rokitman is offline   Reply With Quote
Old 12-19-2018, 10:29 AM   #8
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
I run my fridge on inverter from time to time. It draws over 400watts when cooling. Propane is far more efficient - that draws about 50 watts of 12v power when cooling.
I’m fine with a huge lithium battery bank but on regular lead acid I would and have always run using propane going on down the road.
wulfraat is offline   Reply With Quote
Securing Entry Door while underway John Oliver Doors & Locks 55 04-14-2020 01:56 PM
'64 Tradewind Full Monty Underway... kmtanner Repairing/Replacing Floor &/or Frame 15 04-04-2017 09:44 AM
Staying cool in the lounge while underway Hi Yo AG Roof Vents, Skylights & Fans 16 06-05-2016 04:35 PM
inverter to power fridge while driving? duggie Batteries, Univolts, Converters & Inverters 39 01-24-2015 05:28 PM
Lunar Eclipse underway Boondocker Off Topic Forum 4 03-05-2007 11:26 AM
