Old 06-18-2021, 07:10 PM   #1
Thousand Oaks , CA
inverter power and TV
The TV and projection TV will not turn on with the inverter on. Goes on than off quickly. I put a multi meter on both outlets and it indicates 138V.
Any ideas as to what is wrong?
candrews768 is offline   Reply With Quote
Old 06-18-2021, 07:52 PM   #2
gator.bigfoot's Avatar
KW , Ontario
Will it power a laptop charger or something else that has a very low wattage. Technically it shouldn't have any issue with something around 500 watts. You could try a seeing if it powers a light bulb as well. If it powers these, then your problem might lie with the TV. Try powering your TV from shore power and see if it works that way.
gator.bigfoot is offline   Reply With Quote
Old 06-18-2021, 08:02 PM   #3
DKB_SATX's Avatar
Alamo Heights , Texas
138v is weirdly high. Healthy inverters aren't off nominal voltage by anything like that (that's 15% high)
— David
Old 07-20-2021, 01:29 PM   #4
Thousand Oaks , CA
Further info
. Red/orange light on. Low battery indication (fully charged, and new) VAC vary by wide range. Then turns off
30RB Inverter Needs AC Power For Passthrough to Inverter plugs dsatwork 2011 - 2015 International 1 04-28-2021 10:50 AM
prep for my solar future: Inverter charger/inverter-converter combo wonderlust87 Electrical - Systems, Generators, Batteries & Solar 1 09-13-2017 10:50 AM
Best way to wire inverter/converter/shore power for seamless AC power justgoclimb Batteries, Univolts, Converters & Inverters 39 06-28-2017 04:51 PM
Parallel non inverter generator with inverter generator? mtbguy Generators & Solar Power 3 07-15-2015 01:48 PM
