RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 10-25-2020, 09:47 AM   #1
Lafayette , Louisiana
Inverter not working
2019 flying cloud seems my inverter not working
Everything fine on shore power and when tv running but won’t draw from batteries
Plan to get 2 lithium batteries and 3 solar panels at jc next month and have new inverter for lithium 6 k
Also will have a few issues addressed
Is this a good plan
Whitn37140 is offline   Reply With Quote
Old 10-25-2020, 10:43 AM   #2
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Have you turned it on? The inverter can draw down the batteries severely if the outlets it powers are used inadvertently, so you have to turn it on via a switch in the kitchen, then plug in each device you want to use in an outlet marked Inverter. Only the furnace and overhead lights will draw from the batteries directly, and those will use AC current first if it is available.
A flat screen TV doesn't draw a lot of current, but a toaster, hairdryer or other heat producing appliance will quickly deplete batteries.
I believe having the battery switch in STORE mode would also disable the inverter.
Old 10-25-2020, 12:45 PM   #3
richw46's Avatar
Lexington , Kentucky
Inverters are directly wired to the batteries, they don't go through the Use/Store switch. They usually have 2-3 dedicated outlets. Mine have a blue label between the 2 plugs on each outlet which says it's for the inverter.
So if you aren't on shore power you need to be plugged into one of them and the inverter switch in the galley has to be turned on. (Don't forget to turn it off or you will run down the batteries if you don't have solar.)
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE
Most of us don't know exactly what we want, but we're pretty sure we don't have it. -Alfred E. Neuman
richw46 is offline   Reply With Quote
Old 10-25-2020, 12:55 PM   #4
richw46's Avatar
I can't speak for the Interstate models but the trailer's furnace motor and overhead lights are always 12 VDC. If plugged into shore power the converter provides the 12 VDC. If not on shore power the Use/Store needs to be in Use position to draw power from the batteries for the furnace and lights. (Maybe that's what you're saying and I have misunderstood.) Inverters are wired directly to the battery and can be used even if the Use/Store is in Store position.
Some inverters are plugged into 120 VAC and can power the inverter outlets when the inverter isn't on (pass through), some don't. (Mine is capable of that but there never was a plug provided for it.)
-Rich
Rich & Yvonne
2004 4Runner SE
Old 10-25-2020, 02:46 PM   #5
daleyocum's Avatar
2018 25' Flying Cloud
Portland , Oregon
Is this a good plan
Contact Ronnie (GMFL on this forum) to get a competitive bid on your electrical upgrade. He’s based in Alabama and might be able to get you a lot more more your money. Check out the Long Long Honeymoon youtube on their upgrade he did.
daleyocum is offline   Reply With Quote
Electic Jack not working - fuse good - manual not working ryandanz Jacks, Stabilizers, Lifting and Leveling 20 04-24-2016 11:04 AM
1000W Inverter not working even with full battery corymac Airstream Trailer Forums 9 12-16-2014 08:25 PM
Inverter not working btowntincan Batteries, Univolts, Converters & Inverters 4 07-08-2014 05:27 PM
Inverter not working? susans69 Electrical - Systems, Generators, Batteries & Solar 3 05-18-2012 11:05 PM
Inverter outlets not working FinnSwede Batteries, Univolts, Converters & Inverters 10 11-16-2011 04:14 PM
