Selling the 23 international 23fb. Buyers inspector came today. The inverter is not working. We have not the need to have used it. The few times we used it we were plugged in. The unit has solar up top. Again we have never used or attempted to use. Not sure if this was an issue in September when we bought used from dealer or not. I do not remember if we checked that during PDI. We checked a ton of stuff I remember just not this particular thing. All is good with everything else in trailer and all
12v stuff works as it should and 120v stuff when umbilical is plugged in.
All breakers good. Nothing tripped.
Inverter is Victron Energy 3000. Multi plus. Inverter switch has 3 positions. Charge. Off. On. . When On. Green light does not burn fan does not run. It has a Bluetooth dongle which I assume is related to an app or maybe solar. It has a blue light flashing for Bluetooth. The solar box in this same front compartment is dark regardless of hooked to umbilical or just on battery power. Battery switch is turned to On.
Maybe someone been here done that and there is a fuse on inverter somewhere that fails ? Or some other easy fix ?
Thank you in advance for your help
