Old 01-15-2025, 09:36 PM   #1
2020 16' Basecamp
Fargo , North Dakota
Inverter install: Please comment and critique
2020 Airstream Basecamp 16X. Progressive Dynamics PD1620 2000W inverter.
Name:	Basecamp wiring diagram with 7 pin.jpg
rbrak29 is offline   Reply With Quote
Old 01-16-2025, 06:58 AM   #2
2025 25' Flying Cloud
2024 Interstate 19
Noblesville , Indiana
What are you trying to accomplish? Do you have an air conditioner?
vanderwielen is offline   Reply With Quote
Old 01-16-2025, 08:23 AM   #3
2020 16' Basecamp
Will be only using the microwave and occasionally a hair dryer. Will not be using the AC.
I tow with a Rivian R1T which I charge at every campground (50A). Using an inverter I would not have to hook the BC up to the campground pedestal or to the truck's AC power. BC has 180W of rooftop solar with 2 100Ah Battle Born batteries.
Old 01-16-2025, 10:31 AM   #4
2022 33' Classic
Chesapeake , Virginia
I assume the 2/0 cable is adequate for the load, based on length? I have no idea how long that run to the battery box is. What is the black circle to the right of the battery, on the red cable?
BGClassic is offline   Reply With Quote
Old 01-16-2025, 12:46 PM   #5
JeffKim's Avatar
2023 25' Globetrotter
2021 16' Bambi
Forest Lake , Minnesota
Don't forget the fusing on the DC side. 2000W is about 166A or a 200A fuse or so. Type T is best, but a MRBF is probably good enough. Or is that the round thing?
From the wiring calculator 2/0 wire will get you to around 25' R/T, but I'd guess you know that.
If it's still a consideration, we get by just fine with our 1000W inverter, but then we don't use the microwave hardly at all even when plugged in. That would reduce the wire quite a bit. AS has 4AWG going to our inverter.
Last, I'd look into some sort of relay to automatically switch off the charger in case you forget. I'm pretty sure they exist but I haven't had the occasion to research them.
2023 Globetrotter 25FBT "Curly"
2017 Audi Q7 3.0T
WBCCI 6343
JeffKim is online now   Reply With Quote
Old 01-16-2025, 12:56 PM   #6
2020 16' Basecamp
Thought about some mechanism to shut off the charger. I think will put the remote for the inverter right next to the breaker panel with a note about shutting charger off.
Old 01-22-2025, 11:33 AM   #7
2021 30RB Classic
West Sacramento , California
Check ampacity
Cant tell from the diagram but you got to be running some huge wires to the inverter. And probably need another 200ah of lithium. You need to look at a ampacity chart
I studied this closely for my 30’ Classic and just could not justify the work for the return.
pboomerx is offline   Reply With Quote
Old 01-22-2025, 12:02 PM   #8
2022 33' Classic
pboomerx,
You have a valid point. We upgraded because we were going to Alaska, and wanted the capability to off-grid it at Provincial Parks. We have four 100Ah BBs, and a MP-II 3000. It's all about what you want to do with your RV.
Please critique my solar array layout! Creampuff Generators & Solar Power 0 06-04-2023 03:33 PM
Basecamp inverter install schematic. Please comment rbrak29 Batteries, Univolts, Converters & Inverters 0 01-20-2023 10:15 AM
Please Critique my Winterizing Approach--2022 Globetrotter 25 FBT Tyler2you Winterizing, Storage, Carports & Covers 38 01-13-2023 07:24 AM
Isuzu Engine critique Versatile Mechanics Corner - Engines, Transmission & More... 25 01-20-2008 10:29 AM
design critique of a 60's caravel urbanfood Our Community 23 09-29-2005 05:48 AM
