Old 12-13-2016, 05:50 PM   #1
2015 30' Classic
Roseburg , Oregon
Inverter electrical plug
What is the male pigtail coming out of the inverter for? It doesn't seem to be plugged in to any outlet. Thank you.
Molly Presto is offline   Reply With Quote
Old 12-13-2016, 08:36 PM   #2
New Borockton , Alabama
Images: 21
It's for the inverter bypass relay. When plugged into an outlet and AC is sensed, it will shut down your inverter to prevent damage. Conversely, if your inverter is on and in the standby mode and AC power is lost, it should kick the inverter on, similar to an uninterrupted power supply (UPS) Often they install a separate transfer switch/relay instead and in that case it would not be needed since they essentially do the same thing.
Randy...Converters, Inverters, Trimetric, Surge Protectors, Zamp, Smartplug, AGM Batts
888-828-1893
Bestconverter.com
Old 12-15-2016, 03:38 PM   #3
2015 30' Classic
Roseburg , Oregon
Thank you.
Thank you. So how do I know whether I have a separate transfer/relay switch and therefore do not need to plug it in?
to plug in or to not plug in...that is the questions 4hartungs Batteries, Univolts, Converters & Inverters 39 04-23-2014 03:44 PM
inverter plug katsix General Interior Topics 4 06-20-2008 02:34 PM
Trailer plug - Adapter or New Plug?? Jason1101 Brakes & Brake Controllers 4 01-23-2003 05:24 PM
