Originally Posted by banderabob
Looking at purchasing a 2012 23D. The paperwork indicates it has a 600w inverter system ( along with a 110v/12v power center w/ 55 amp converter). Am I correct that the inverter is what would allow me to run accessory appliances, the TV and A/C when not hooked to shore power or a generator?
You CAN operate heavy draw AC appliances like a microwave or a roof A/C from a battery/ inverter combination, but you need the correct components.
You definitely CAN NOT operate much from a 600 watt inverter and basic 160 amp/hour battery bank.
To accomplish the above, you need a minimum of a 1600 watt unit ( Victron 12/2000 Multiplus) for a microwave or a larger 12/3000 Multiplus; Magnum MS-2812 or MSH-3012M hybrid for A/C operation. With any of these devises, you also get a fully programmable charging section with temperature compensation for perfect battery charging
These should be coupled with an appropriately sized battery bank to handle the loads and anticipated run times.
Lew Farber
