Old 06-28-2020, 10:14 AM   #1
Knoxville , Tennessee
Interstate 19 House Battery drain
New 2020 Interstate 19 with two new house batteries. Originals replaced after sale since unit sat at dealership several months without charging up.
Anyone having problems Boondocking?
With only the DC Frig running I get a critically low battery message after only about 12 hrs use. Even with solar panels catching some sun.
Any tips on extending life of batteries? Just seems like two fully charged batteries should last longer. Dealership in the dark " new unit not sure why?"
thanks for any suggestions.
Netpilgrim is offline   Reply With Quote
Old 08-01-2020, 03:45 PM   #2
2016 19ft flying cloud
Spokane , Washington
More than likely something else is drawing down batteries ....inverter turned on? Radio? Storage lights ? I would have a Victron 712 installed, that way you will always know how many amp hrs you are consuming
Spinonedad is offline   Reply With Quote
Old 08-01-2020, 03:52 PM   #3
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
The Interstates, and probably the others, as well, are notorious for draining batteries. You'll probably find about all you can do is conserve all you can. One biggie you can probably do something about is the inverter. Use a manual cutoff switch for it, since it draws a significant amount of power even when off.
Old 08-01-2020, 04:19 PM   #4
old/new member
preedtx's Avatar
My 2020 19 has a manual cutoff located next to the inverter under the front passenger seat as in this photo.
2020 Interstate 19
Give me 40 feet and I'll turn this rig around.
preedtx is offline   Reply With Quote
Old 08-01-2020, 07:05 PM   #5
1993 21' Sovereign
Is that the master disconnect, or wired only to the inverter?
Old 08-01-2020, 07:46 PM   #6
old/new member
preedtx's Avatar
The master disconnect, which is similar to this one, is located in the rear under the sofa seat and can also be activated by the power off switch near the sliding door.
2020 Interstate 19
2016 interstate grand tour house battery problems Camerons Sprinter and B-van Forum 7 01-02-2017 08:50 AM
2007 Interstate T1N rear sofa house battery remove and replace bugsbunny Sprinter and B-van Forum 1 07-15-2016 10:28 AM
2005 Interstate house battery jwwhidbey Sprinter and B-van Forum 3 05-09-2010 05:02 AM
Interstate house battery change EIDAM3 Sprinter and B-van Forum 5 07-13-2009 10:14 AM
