Interesting charging issue: Battleborn and PD4655
So here is the set up:
2 x 100Ah Battleborn batteries
PD4655 Li Converter charger
Victron 702 battery monitor.
Today I noticed the converter clicking on and off, so I looked the Victron app and sure enough, there is a weird charging behavior. The voltage is only 13.2V or so and it is cycling every 30s or so. This is happening regardless of which of the two 30amp connection I use and regardless if on shore power (20A service as I can't reach my 30amp right now) at the house or on the 3100W champion generator. So the transfer switch is probably fine.
All interior systems 110v/12v are working fine.
My suspicion is the converter is failing. I have the older PD4655 I just pulled out of the garage, but before I switch it out I thought I would post here in case anyone had any thoughts.
Could the BMS on the 2 battleborns be playing silly games????
