Old 11-16-2020, 04:54 PM   #1
DaveP's Avatar
2004 28' Classic
Monument , Colorado
Installing DC-DC Charger for Lithium Battery Isolation
I am installing a Renogy 20-amp DC-DC Charger to isolate the lithium batteries in the trailer from the tow vehicle’s LA batteries. My plan is to run 4-gauge wire from the vehicle battery to an Anderson power pole connector at the rear bumper (with a 30-amp fuse in the positive line). I will connect the lines into the trailer to the charger input, and then run lines from the output to the positive and negative bus bars.
I will disconnect the positive and negative lines that come in through Bargeman 7-pin connector and cap them.
I know I will not get much charging from this system, but I will get some. I am not running one of the larger chargers (40 or 60 amps) because I am not sure the computer-controlled alternator in my 2014 F150 Ecoboost could handle a larger load. Mostly I just want the isolation.
Anybody see any issues with this plan or lay-out?
Thanks, Dave
DaveP
2004 Airstream Classic 28 "Willard"
2014 Ford F150 FX4 Ecoboost
DaveP is offline   Reply With Quote
Old 11-16-2020, 04:59 PM   #2
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
No issues, you have a very good plan, in my opinion. I think you could go 30 or 40A even with the wiring and connectors you have in mind. But check your alternator output first, it should be over 130A to go larger than 20A.
We do these installs just about every time when converting to Lithium.
Uwe
www.area63productions.com
Old 11-17-2020, 12:18 PM   #3
uwe
418
uwe's Avatar
1974 29' Ambassador
Images: 41
Another thought to make your plan even more appealing would be to use the existing charge line, route it through a relay that makes it active only with ignition on, and then use the trailer side of it to turn on your dc/dc charger. Like a remote switch that is fully automatic. Of course you would need a dc dc charger that allows this function, such as Victron Orion or Sterling product. Perhaps your Ford's charge line is already controlled by the ignition switch, I am not sure.
Uwe
Old 11-17-2020, 02:40 PM   #4
DaveP's Avatar
2004 28' Classic
Monument , Colorado
That is actually (kind of) what I had in mind. The Renogy has an on/off circuit plug on it. I am going to wire it to the running lights (on the trailer circuit) which I always use when towing because they power my rearview camera. That way, I do not mess with the 7-way plug/circuit as I use the truck to tow other trailers than the AS.
Thanks for your advice. Always like to have a second (or more) opinion(s) on my designs in case I miss something.
DaveP
Old 11-17-2020, 03:21 PM   #5
1994 21' Sovereign
Knoxville , Tennessee
I have installed the same system and it works great. you said you were going to cap the positive and negative on your pig tail. I would leave the negative alone. I actually ran a single “ignition on” hot wire plug mounted next to the Anderson plug on the tv.
Khale is offline   Reply With Quote
Installing a 2nd fridge in 22' Sport (or installing larger fridge altogether)? skicrazy801 2005 and newer - Bambi all models 12 09-22-2019 02:43 PM
Installing a 4-stage converter/charger in your new Airstream Msmoto Batteries, Univolts, Converters & Inverters 123 07-29-2019 10:36 AM
Suggestion on installing an aux 12 V charger mlidaho Phone, CB & Ham Radio 12 09-11-2018 10:14 PM
Converter/Charger vs. Inverter/Charger moosetags Batteries, Univolts, Converters & Inverters 5 11-22-2013 11:21 PM
Adding charger where no charger has gone before Jabba Electrical - Systems, Generators, Batteries & Solar 4 03-08-2003 10:39 AM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
