Old 02-24-2020, 05:49 PM   #1
2019 28' Flying Cloud
Dripping Springs , Texas
How to get the Victron BMV-712 to stop scrolling?
What is the BMV-712 supposed to do when it is idle? I would like that little external display to be completely OFF: no light, no scrolling, no status. Is that even possible?
I went through the Bluetooth setup and everything looks ok. Setup up my dual Trojan batteries per the excellent guide at AM Solar. Capacity 225Ah. Disabled all display features entirely.
Yet the unit still scrolls something like "Battery capacity..." repeatedly. Won't this kill the battery?
Thanks!
Kalashnikov is offline   Reply With Quote
Old 02-24-2020, 05:53 PM   #2
Overkill Specialist
GMFL's Avatar
2020 30’ Globetrotter
2014 23' International
Dadeville , Alabama
Press the setup button on the monitor itself. That should fix the problem.
Instagram @Airstream_Nuts_And_Bolts
DoItYourselfRV Articles
Certified Victron Installer
Old 02-24-2020, 08:53 PM   #3
Ok I'll try that.
And that's all- just a single press? It won't go into some "setup" mode after that?
Old 02-25-2020, 11:32 AM   #4
The Aluminum Tent 3
pcskier's Avatar
2014 23' Flying Cloud
Park City , Utah
I don't know if you can choose a hard 'off' setting, but the BMV-712 draws .7 ah per MONTH. It will have absolutely zero material effect on your batteries. I put my trailer (with t105s also) in storage 9 weeks ago, in a cold winter environment, with the batteries switched completely off via a Blue Seas switch. During that nine weeks I visited twice and turned on the batteries to run the furnace, for a total of probably 90 minutes. When I went by yesterday to check on things, the batteries were sitting at 12.6 volts. With them switched completely off, it is like they are sitting on a shelf and the self discharge rate is very low, with the BMV 712 drawing virtually nothing. Don't worry about it.
pcskier is offline   Reply With Quote
Old 02-25-2020, 11:45 AM   #5
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
Originally Posted by Kalashnikov View Post
Ok I'll try that.
It’s in setup mode now. That should get you out of it.
Victron BMV 712 setup wareaglewalt Batteries, Univolts, Converters & Inverters 17 02-10-2020 07:39 PM
Victron BMV-712 panel lights turn off? marter Batteries, Univolts, Converters & Inverters 7 08-18-2018 11:37 PM
Question regarding Victron BMV-712 billrector Batteries, Univolts, Converters & Inverters 26 05-30-2018 03:21 PM
victron BMV-712 with battery temp probe waninae39 Batteries, Univolts, Converters & Inverters 1 04-23-2018 07:53 PM
Victron BMV-712 install in 2017 30 International dmcgaugh Batteries, Univolts, Converters & Inverters 3 03-09-2018 12:24 AM
