05-29-2024, 10:15 AM
#21
2023 33' Classic
Chandler
In all the years of having LifePo4 batteries, ive never worried about them being full.
Yes a full charge will get me to 14.6Vdc, but within a few hours they'll drop to their normal 13.2-13.6 vdc, they can stay that way for months on end with zero worries. Now with 1K watts of solar on our classic 33, the batteries no matter what SOC they are in they fill to 100% fairly fast. With the 12v fridge/freezer running 24/7 they will pull the batteries down some. But I will admit i always run my aldi heater utilizing electricity only, since it is easily replenishable. having 840 ah of LifePo4's does make boon docking for weeks on end gratifying.
05-29-2024, 10:33 AM
#22
Fayetteville
Lithium bank use
Just curious… some are saying they take their batteries to 100 pct. Some mention 70-80 pct. What is your voltage at 70 pct vs 100 pct?
05-29-2024, 10:59 AM
#23
2019 25' Flying Cloud
Houston
It's difficult to figure out state of charge by voltage. LiTime says 100% is 13.33, 75% is 13.3, and 50% is 13.15. Not much difference. I think most folks get state of charge from a smart shunt or from the battery's bluetooth app. My app gives me state of charge and voltage. The last reading I got was 99% for both with one at 13.6v and the other at 13.5v. Which isn't even consistent with the table I quoted above.
05-29-2024, 11:52 AM
#24
2020 25' Globetrotter
Santa Rosa
FWIW and just to clarify, I don't worry about fully charging my batteries when in use while camping either. I do question keeping them constantly at 100% while in storage given that, anecdotal evidence aside, there is some information that this may not be good for them in the long run. Whatever.
Mike
2020 25' Globetrotter Twin | 2024 GMC Sierra 2500HD Denali Ult. 4x4 Duramax
400Ah Battle Born lithium battery string | 580W solar (400W roof 180W portable)
05-29-2024, 12:37 PM
#25
diesel maniac
Airstream - Other
Tucson
, AZ
I store mine at 50-80% and for travel I fill them up just like the fuel tank. Like mentioned, there are probably more charge cycles than the average user will ever see before they just age out.
Brian
05-29-2024, 09:17 PM
#26
1994 25' Excella
Waukesha
, Wisconsin
I agree - no was to get SOC from the voltage level. The voltage level of lithium batteries remains nearly level as they discharge and doesn't drop quickly like traditional lead-acid batteries do. Voltage drop from the wiring to/from the meter only complicates the readings.
Only accurate way to know SOC is with a shunt-based monitor.
Richard
11018
1994 Excella 25 'Gertie' Follow the build on Gertie!
1999 Suburban LS 2500 w/7.4L V8 'Bert'
1974 GMC 4108a - Custom Coach Land Cruiser 'The Bus' (Sold)
05-30-2024, 08:54 AM
#27
2023 33' Classic
Chandler
When they are fully charged, the battery voltage becomes 14.6V. It drops to 10 volts when fully discharged. The below 12V LiFePO4 battery voltage chart reveals how the voltage drops with respect to battery capacity.
05-30-2024, 10:15 AM
#28
1994 25' Excella
Waukesha
, Wisconsin
Your chart pretty much shows what I said earlier...The voltage drop for lithium batteries is pretty much flat except for a few percentage at the beginning and at the end.
Lead acid batteries would have a pretty sloped line all the way down with much more constant dropping of voltage all along the graph.
Richard
11018
05-30-2024, 10:59 AM
#29
2021 Interstate 24GL
LiFePo4 Chart Voltage
Thanks for posting. Helps illustrate SmartShunt value to understand use, minimize use, or justify use over a set SOC
05-30-2024, 02:09 PM
#30
2023 25' Globetrotter
2021 16' Bambi
Forest Lake
A teensy-weensy correction. The charger will charge at 14.4V however the fully charged battery voltage depends on the brand, usually it's around 13.6V as stated by others here.
2023 Globetrotter 25FBT "Curly"
2017 Audi Q7 3.0T
WBCCI 6343
06-01-2024, 05:11 AM
#31
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Over the usable range lead acid goes from 12.6 to 12.0 volts at 70 F. Those voltages vary up to 0.6V over temperature.
LiFePO4 runs from 13.4 to below 12V over the usable range. They don’t vary much with temperature.
You need a shunt with both types of battery.
06-01-2024, 06:11 AM
#32
1994 25' Excella
Waukesha
, Wisconsin
Correct, and I agree about the value of a shunt with both.
The voltage range on the lithium is as you say, but the difference is that for the majority of the cycle the voltage holds steady. There is an initial drop after charging, and then things hold steady for quite a while. It's not till the lithium batteries get in their lower end of useful capacity that the voltage starts to drop noticeably again. Look at the graph in post #27 and you'll see the long stretch of horizontal.
Lead acid batteries have a graph which show a noticeably diagonal line with the voltage dropping during the entire cycle and not just at the ends. This makes it possible to get a rough estimate of SOC using voltage.
Richard
11018
06-01-2024, 06:17 AM
#33
Fayetteville
Lithium Banks
Another thought that was given to me by a certified technician was: If you want to get an voltage read out of what your batteries voltage “actually” is, check it when not connected to the tow vehicle or shore power.
06-01-2024, 06:43 AM
#34
Houston
Or batteries with a bluetooth app.
06-03-2024, 03:03 PM
#35
2020 22' Bambi
2022 25' Globetrotter
St-Laurent
, Quebec
Originally Posted by Peter C
My three 100 amp hour BB10012 are over five years old. We just live our best lives and do not worry about regular discharge. I do pay attention to the state of charge when heading to a dry/boondocking location. They seem to be holding up very well and hopefully in a few years we will replace them with a couple of game changers or similar.
Note I live in Canada and leave the batteries in the trailer (they are under the bed) over the winter at 100% with roof solar connected.
I do the same. 500 AH of BBs under the bed. I let them be when in storage and solar tops them off eventually to 100%. It’s been 3 seasons of use and the full charge voltage hasn’t really budged. Maybe I’ll regret it someday but maintaining a lower state of charge, unlike in an EV, would be too much manipulation, at least for me.
