Old 05-29-2018, 09:03 AM   #1
1978 31' Sovereign
Brooklyn , New York
How are duel batteries configured in a 78 Airstream
I have a 78 Sovereign. When I hook one battery up ( the one on the right facing from the outside ). The electrical system works, I can push test on the solid state panel etc. When I hook the other battery up, nothing, no juice.
Do both batteries need to be hooked up at once fo it to work? ( like a primary and secondary battery )
Are these connected in parallel by default ?
I hooked up a solar charger to battery 1 under the assumption that the batteries are connected in parallel and therefor it would charge both batteries, but now I'm not sure if that is correct.
estock is offline   Reply With Quote
Duel Range Auxiliary Transmission Jim Keaty General Motorhome Topics 6 09-04-2017 06:41 AM
Duel Fuel Generator and a direct connect to LP? jkauker65 LP Gas, Piping, Tanks & Regulators 1 05-05-2017 09:56 AM
Duel fuel generator The Colonel Generators & Solar Power 3 03-12-2017 09:56 AM
Duel Fueling a Dometic 50 beatrix1 Refrigerators 2 03-03-2015 06:35 AM
Batteries..All about batteries FrankR Batteries, Univolts, Converters & Inverters 0 07-17-2002 09:05 PM
