08-26-2016, 06:05 PM
The Woodlands
House Battery Life
Regarding my 2015 AS Interstate...any idea how long I could reasonably expect the house batteries to last when parked with no shore power, engine off and no generator? I know it would depend on many variables of power usage, but assume one TV, fridge and occasional light. Would we be talking a matter of hours or days???
08-26-2016, 06:20 PM
New Borockton
How many and what size batteries? A pair of group 27s should last all night in the summer if not running the furnace and a bunch of lights. You said TV and fridge so either you have a DC TV and fridge or using an inverter which will use more DC power to run itself too. Like you said, lots of variables. Fridge is a heat source and uses quite a few amps.
888-828-1893
Bestconverter.com
08-26-2016, 06:55 PM
The Woodlands
House Batteries Life
I have (2) AGM Group 24 house batteries and a 50amp multi-stage charger, 1000 watt inverter.
08-26-2016, 07:10 PM
Naples
House Battery Life
Assuming that you have the original Lifeline AGM batteries and the Magnum MMS-1012 inverter/charger, your battery life will be dependent on the following conditions:
• the average depth of discharge (DOD) that the batteries have experienced. The greater the DOD, the fewer charge cycles and associated battery longevity you can expect.
• amount of time left in a depleted state. The longer any battery is left in a deep DOD state, the more sulfation can form on the plates which will inhibit the batteries from receiving a full and complete charge, effectively decreasing the total capacity of the batteries.
• overall use of the coach. Many folks experience longer battery life when they rarely use their RVs, but keep them connected to shore power which will allow the batteries to be maintained in the float stage for extended periods. Minimal battery use also extends battery life.
The overall health of your batteries is impossible to ascertain without putting them thru a complete test with a conductance meter, as their history of charging and use is a complete unknown.
Once the battery capacity is determined, the number of available amp/hours of capacity can be calculated and they will provide you with up to 50% of their total.
Add up the loads you will be using and you can then determine exactly what your battery life will be for any given situation.
Lew Farber
lewster
08-28-2016, 05:57 PM
New Borockton
Without a battery monitor like the Trimetric that totals amps or amp hours consumed (and replenished) it will be a guessing game. Curious what 50 amp charger you are referring to since they don't come it that size unless its a battery charger you purchased separate but since your question excluded shore power or generator it really is irrelevant.
888-828-1893
Bestconverter.com
08-28-2016, 06:46 PM
Naples
The Magnum MMS-1012 inverter/charger fits his description as it is a 1000 watt inverter with an integrated 50 amp 4-stage charger.
Lew Farber
lewster
08-28-2016, 07:03 PM
New Borockton
Lew Farber
10-4 I didn't know he had that, figured stock WFCO inverter and some other converter. Glad he's upgraded to something
888-828-1893
Bestconverter.com
08-28-2016, 09:03 PM
Wise Elder
2010 30' Classic
South of the river
The stock setups typically give you 2-3 days if you're not running the furnace or any of the fans. If it's cold and you're running the furnace a lot you'll maybe get one night.
It varies widely though with how good you are at conservation and what kind of shape your batteries and charging system are in.
11-18-2017, 08:09 PM
2023 Interstate 19
Colorado Springs
Lewster, Great information all over this forum, Thanks. I am purchasing a 2016 AI 3500 GT Ext and wish to determine the battery health. You mentioned.
"The overall health of your batteries is impossible to ascertain without putting them thru a complete test with a conductance meter, as their history of charging and use is a complete unknown." What test is required and is this something the dealer can perform?
11-27-2017, 04:20 PM
Naples
Howdy!
The only way a dealer can run a conductance test is with a conductance meter. I have one but many dealers do not! In fact, I would be hard prodded to not only find a dealer with one, but also the appropriate staff who is knowledgable to use one PROPERLY!!!
I would call around to find one and if not, call ME!
lewster
