Old 02-16-2021, 03:26 PM   #1
2018 25' Flying Cloud
Dadeville , Alabama
High voltage on panel above the sink
My panel reads 18 volts. This is true when plugged into shore power or not, converter breaker switch on or off, and no solar panels. At the batteries, my multi-tester says 12.5 volts on both batteries (I just replaced them today) with shore power connected and the converter breaker switch on. Battery cables and batteries are not warm.
Has anyone else experienced an erroneous readings on their panel? I know the water level and gray/black levels can be erroneous.
If its not the panel then the converter may be may faulty?
Thanks in advance for any tips.
Viperdogg is offline   Reply With Quote
Old 02-16-2021, 04:02 PM   #2
Long Island , New York
Your other thread FEI:
https://www.airforums.com/forums/f44...ng-219443.html
Let the music lift you up . . .
Have a little pun in life . . .
Peter
OTRA15 is online now   Reply With Quote
Too High Battery Voltage? TankerIP Batteries, Univolts, Converters & Inverters 14 08-08-2010 08:58 PM
High Voltage in Mexico cooney Electrical - Systems, Generators, Batteries & Solar 2 12-19-2008 06:01 PM
High Voltage Power lines and batteries safari57 Batteries, Univolts, Converters & Inverters 9 10-31-2006 10:31 PM
One sink, two sinks, red sink, blue sink? Janet H General Interior Topics 7 07-26-2006 06:17 PM
High Voltage kooblekidz Mechanics Corner - Engines, Transmission & More... 8 02-05-2004 07:32 PM
