Hi Folks,
I have the same issue with our 2019 Globetrotter- the inverter seems to be completely dead (no read out on panel, no green flashing light), and the remote panel LED does not light up. I followed the advise in this thread and did the following:
1. checked breakers at panel, turned all breakers off and back on
2. checked the fuses - all good
3. checked breaker on inverter -not tripped
4. checked for power at the inverter
At step 4., things get interesting. The volt meter shows 30 volts! Either I don't know how to use the volt meter correctly, or the batteries are not hooked up correctly. The two
12v batteries appear to be wired in parallel. The negatives are connected, and the positives are connected.
Looking for any ideas on what might be going on here.
Thanks!
