Old 08-13-2020, 09:17 AM   #1
Josie.Small's Avatar
Atlanta , Indiana
General Electric questions.
1972 22ft Airstream Argosy
I need some electrical help, we’ve got old wire, new wire, a new air conditioner coming in. We be got a converter, an old fuse box(pic attached), but not distributor. So I’m wanting to convert everything into one sub panel that includes all that. I’m not sure what I need, here’s a picture from my original manual. Links would be appreciated.Click image for larger version
ID:	375737Click image for larger version
Josie.Small is offline   Reply With Quote
Old 08-13-2020, 09:28 AM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Your trailer has 2 electrical systems. The 120 volt AC (shore power) system which has the circuit breakers that you attached the picture to.
You also have the 12 volt DC system which runs off the battery and the univolt which converts the 120 AC to 12 DC. The DC system will have a distribution and fuse panel located in an area near the battery.
I would upgrade the 12 volt DC system with a new converter and battery(s). The details of your system should be based on how you will be using your trailer.
Richard
Old 08-14-2020, 11:08 AM   #3
Atlanta , Indiana
So I do NOT have a panel for the DC system. I’ve looked.
General Overlander Questions surely 1960 - 1964 Overlander 7 06-17-2008 04:55 PM
General Questions dmcclintock 2008 Safari SE 5 05-22-2008 06:34 AM
General Electrical questions LHall Batteries, Univolts, Converters & Inverters 7 08-07-2007 12:41 PM
General Engine questions from a newbie ErichC Mechanics Corner - Engines, Transmission & More... 1 07-07-2002 05:23 PM
