Old 07-18-2017, 09:48 AM   #1
Traveler
TravlinMan's Avatar
2017 25' International
Staunton , Virginia
Elevation
Was makin my coffee this mornin and got thinkin about elevation changin up the boilin point and then I started thinkin what good is my battery temp sensor if it don't know my elevation? If I'm at 10,000' ain't my converter gonna boil the batteries if it uses the same voltage as it does at 0'? Am I overthinkin this?
TravlinMan is offline   Reply With Quote
Old 07-18-2017, 09:57 AM   #2
Long Island , New York
Won't the temp sensor take care of this, at least indirectly? I forget do you have AGM's or lead cell flooded? The dual use of the word "boil" may result in some over-thinking IMO. Is the chemistry of water boiling at 212F similar to batteries boiling due to overcharging?
Beyond my knowledge, but a good question!
Peter
Old 07-18-2017, 10:03 AM   #3
Traveler
TravlinMan's Avatar
Staunton , Virginia
I still got the interstate wet batteries.
The thing is that the temp sensor only measures the surrounding area of the battery. So its never gonna sense 195 degrees or more. It don't know the temp of the water, just the environment. Also, even if it knew the temp of the water, if it thinks the boilin point is 211 but it's actually 195 cause of elevation... How does it account for that? Im just tryin to uderstand the science here....
Old 07-18-2017, 10:11 AM   #4
The thing is -- it is no longer "water" IMO. It is a new chemical that started with H2O as a main ingredient. The question would be what is the boiling point of that new liquid, and is it affected by changes in barometric pressure?
Sometimes during really low pressure weather events [hurricanes etc.], the atmospheric pressure probably gets as low as it does at high elevations, yet we have never seen warnings not to charge batteries during a hurricane, for instance.
Guessing a non-issue . . . think I will stop thinking about it . . .
Old 07-18-2017, 10:14 AM   #5
2007 22' International CCD
Elevation
Batteries don't actually "boil" in the sense of heating a kettle of water to the boiling point. What is described as "boiling batteries" is water loss due to overcharging. It's not heating the battery to the vaporization point of water...
Old 07-18-2017, 10:24 AM   #6
Traveler
TravlinMan's Avatar
Staunton , Virginia
Ok thank you. That was just what I was wonderin.
Old 07-18-2017, 11:43 AM   #7
Burnside Bob's Avatar
2009 25' FB Flying Cloud
1973 31' Sovereign
Mt Angel , Oregon
Battery "boiling" from over charging and water boiling are two different processes. In the first, the gasses "boiling" out of the battery fluid are hydrogen and oxygen. In the second, the gas boiling is water vapor.
The first process is driven by electric potential and is not significantly affected by altitude. The second process is driven by heat and atmospheric pressure determines the boiling temperature.
There is a good discussion of gas generation in lead acid batteries in this article (among other topics):
http://www.battcon.com/papersfinal20...008proof_6.pdf
And there is a graph of water's boiling temperature by altitude here:
http://www.engineeringtoolbox.com/bo...de-d_1344.html
And that's probably info overload!!
Best, Burnside
"To err is human, to air is devine."
Burnside Bob is offline   Reply With Quote
Old 07-18-2017, 05:04 PM   #8
Wise Elder
Jammer's Avatar
2010 30' Classic
nope
Yup
Batteries don't reach a temperature where the electrolyte actually "boils." What's going on here is that the voltage at which they are fully charged is lower when temperature is higher. So in order for the converter to know when to stop charging it has to know voltage and temperature. Altitude does not affect the battery to any material degree.
Old 07-18-2017, 05:16 PM   #9
Elevation
Well, actually you can overcurrent a battery to the point that the electrolyte does boil, but it take a lot of current to do that. I've had it happen in a series string of batteries that added up to 120 volts D.C. When one battery shorted out (AGM type) the case ruptured and stared spewing steam (plus acid vapor). Was no fun getting that under control.
It was part of a big UPS system and we think a couple cells shorted out. The battery charge circuit went full current trying to bring the voltage up fast.
Old 07-18-2017, 05:35 PM   #10
Traveler
TravlinMan's Avatar
Staunton , Virginia
Thank you it is helpful for me to try and understand this stuff. I appreciate it.
Ford F150, F250, F350 Pay Load... at Elevation Ray Eklund Tow Vehicles 22 07-12-2016 05:19 PM
Propane and elevation questions scarletbison Sprinter and B-van Forum 5 07-05-2015 09:45 PM
Honda EU3000is at elevation question lewishw Generators & Solar Power 2 02-15-2013 07:21 AM
Suburban sp30 nt elevation rating kewpie Furnaces, Heaters, Fireplaces & Air Conditioning 1 06-11-2011 11:04 AM
Microwave elevation... Paul Ouellette General Interior Topics 7 01-24-2009 08:11 AM
