Old 06-20-2024, 04:39 PM   #1
Charlotte , North Carolina
Ecoflow Power Kit?
Has anyone investigated an installation of the Ecoflow Power Kit 5k in an Airstream trailer yet as an alternative to a traditional Victron-based system? There are certainly pros and cons between the two, but I'd be interested in seeing how it would work.
This video covers the differences:
https://youtu.be/pWnA9Wmw-v8?si=b3h6dKLnRclO5Ubk
Babyrocket is offline   Reply With Quote
Old 06-20-2024, 05:54 PM   #2
Airstream Driver
PeterH-350LE's Avatar
1994 30' Excella
1992 35' Airstream 350
Images: 49
right now you can get Ecoflow Delta pro for great bargain. I use it in the back of my van, solar panel on the roof and a 2000 watt inverter. it will run the roof AC for a couple hours before I reach camp. All this with no exuberant installation costs, for total of 5k if you want to have the dual fuel ecoflow generator for backup charging.
https://us.ecoflow.com/pages/fathers...mPh6T_QE1p2fGA
AIR #13
PeterH-350LE is offline   Reply With Quote
Old 06-20-2024, 06:18 PM   #3
Airstream Driver
1994 30' Excella
Images: 49
or even better deal at HD right now (june 20 24)
https://www.homedepot.com/p/EcoFlow-...W-US/324116200
AIR #13
Old 06-20-2024, 07:50 PM   #4
Delta Pro has a 3600W inverter unless you're talking about just using it as a big battery to power your existing 2000W inverter.
Regardless, I'm looking for insights on the Ecoflow Power Kit installations for an Airstream trailer.
Old 06-20-2024, 09:48 PM   #5
waninae39's Avatar
2022 25' Flying Cloud
NCR , Ontario
go with victron they have around for a long time
great support
better warranty
2023 25' FB FC, hatch, Queen,30A,1AC,Awning pkg, Convection uwave.Multiplus 12/3000-50,700A Lion,MPPT 100/30,Orion-TR 30,Cerbo GX,GX touch 50,Lynx distributor,dual BMV-712, smart shunt 500A&1000A, RUUVI temp/humidity sensors,2 Mopeka LP sensors
NCR,Ontario,VE3HIU since 1978
WBCCI# 21212
waninae39 is offline   Reply With Quote
Old 06-21-2024, 05:54 AM   #6
Airstream Driver
1994 30' Excella
Images: 49
I understood your question about the ecoflow Power kit permanent installation in your trailer. All I offered was an alternative for half the cost, plug and play and portable when you do not use your airstream. When the airstream sits idle for month, the entire system, less the 2000w inverter, powers equipment in my shop.
The 2000w inverter charges the delta pro while driving via the alternator, the solar charges the delta pro all all times, the delta pro powers the trailer via the TT-30 plug, when in motion and when stationary.
AIR #13
Old 07-22-2024, 04:17 PM   #7
2024 27' Globetrotter
Everett , Washington
The Answer is No
When people donít answer or provide alternatives it means they havenít done it. So I guess we are pioneers.
I have a 10kWHr Ecoflow PowerHub I will be installing in my 27í Globetrotter.
I anticipate the biggest problem will be untangling and dismantling the unneeded stuff since the PowerHub is totally plug and play.
I also know it to be a common van electrical system and has proven reliable in vans.
mattbristol is offline   Reply With Quote
EcoFlow and Nest Reefer Sooty Nest 2018 - Current 0 05-02-2024 02:24 PM
Ecoflow Delta Pro 30A airpaloalto Generators & Solar Power 14 06-09-2023 04:59 PM
Question about Ecoflow Max whang Electrical - Systems, Generators, Batteries & Solar 6 11-24-2022 01:38 AM
