04-02-2020, 02:15 PM
2020 25' Globetrotter
Los Gatos
Dropping in GC batteries in 2020 GT
Just drop in, they said. Issue 1 is the battery box insert tray for the 12s is bit too small for my Duracells. Anyone know where I can get a tray to fit? Or do I need one?
Second is the fuse on positive terminal is too high so box lid will short it. Any ideas on different fuse?
04-05-2020, 04:18 AM
2018 27' Globetrotter
Apollo Beach
This is what I did to "drop in" my Duracell EGC2 batteries into my battery box with the same issues as you. First, I flipped the battery tray vertically to keep the batteries from sliding around inside the battery box and possibly shorting against the box. Second, I turned the inverter fuse connected to the positive battery post 1/4 turn and connected it to the bolt clamping the battery cable so it would fit without shorting against the cover. And finally, I got a longer and thicker series connection wire that I installed between the positive and negative battery posts so I could route that wire around the batteries without interfering with the battery caps.
Another option for the battery tray is to cut the lip off from one side so the batteries will fit inside the three-sided tray.
2021 Northern-Lite 10-2 & F350 DRW PSD, 600W Solar/Victron/600A BattleBorn
146 nights 31,000 miles (first 10 months!)
Sold: 2018 GT27Q, 74 nights 12,777 miles
Sold: 2017 FC25FB, 316 nights 40,150 miles
Sold: 2013 Casita SD17 89 nights 16,200 miles
04-05-2020, 01:01 PM
Los Gatos
I get it. Forgot that two 6s in series now so inverter cables go to posts with battery cables
04-09-2020, 03:48 PM
Los Gatos
Inverter fuse
Dear AirMiles
I moved the fuse the way I believe you did and fit is fine but then had inverter issue, pass through was not working and neither was remote switch. Thought I had blown fuse on battery so got new one and installed as you see here. Pass through started working again but no inverter or remote switch working. After talking to WFCO guys (nice guys each working from home) he told me to put voltmeter on inverter. No volts from battery
So, does your pos side and fuse look like mine? I thought the angle against the bolt did not look right so maybe that or something with the fuse. When it stops raining will try connecting it on top to see if that works before trying to move away from the lid again
04-09-2020, 05:31 PM
2016 30' Classic
Hinckley
, Ohio
I would put the fuse on the other side of the bolt. And use a second nut on a longer bolt. There is not much contact the way it is.
In other words tighten up the battery clamp with a longer bolt then put the fuse on the treaded end with a second nut. Flip it over if it works better.
My budget won't stop me from buying something online that I don't need, but the threat of getting promotional
emails every day for the rest of my life just might!
04-09-2020, 05:54 PM
Los Gatos
That should work better than they way it is now. Waiting to see pic from AirMiles. Thanks
04-10-2020, 11:48 AM
Los Gatos
Found problem
The fuse was not seated properly so leaving on the bolt for pos post crimp but better. First question for something electric not working - “is it plugged in?” Navy Air mechanic school, Millington TN 1967
2016 450 GL, EazLift Elite 1000
Renogy 400 watts and 100 suitcase, 30/100MPPT, Victron 712, 6V Duracells
Honda 2200 propane, Weboost Drive X, EEZ TMS
Traded in 2016 Sport 16, 2019 Sport 22
As they say, third AS is what to buy first
04-11-2020, 09:23 AM
Apollo Beach
Picture of my batteries
Here is a picture of my battery box.
