Originally Posted by Silvr_Lining
Yes, I know that deep cycle batteries are the correct ones to use, but I have been given two large (about 125-130 AmpHrs ea & 98lbs ea!) UPS batteries. Being that they have less lead thickness in the mats, how dramatically will their life spans be altered (shortened)?
I'm certain they're deep cycle: A. 125-130 Ah & 98 lb would indicate deep cycle. 98 lbs for 130 Ah is a lot. That indicates a LOT of lead. The main difference between an automotive starting battery is the amount of lead used. Automotive starting batteries are constructed of lead sponge which is lighter and presents more surface area for a faster chemical reaction. If you need to run your starter for more than 90 seconds, you're abusing the whole starter system. Providing maybe five or ten amps to a load for hours requires more lead. B. Why would anybody put anything else in a UPS? A UPS doesn't need to supply the huge, short-duration starting pulse an automotive starter requires but it does need to supply current for a long time.
Granted, a UPS should maintain the batteries on a float voltage almost all their lifetimes, vs. RV usage which depletes their charge regularly. All batteries used in RVs face the same.
There should be no lead in the mats, only in the anode and cathode.
They are rated for ten years in a UPS environment and are five yrs old.
Good luck! We use tons of UPSes at work. I've never seen one last ten years. A little more than five years is all I expect. Maybe seven years.
Since their 12v, I'll parallel them. The other question is how about the converter? I have no information on it. How harsh might that be on the batteries? Their is nothing in the manuals for our 2007 Bambi. The monitor for the trailer is a standard Airstream Micro Pulse Systems Monitor.
The PO had also installed a small (40watt) solar panel and Go Power charge controller, so that will keep a nice trickle on the batteries
-Marc
Sounds to me like you're on the right track. If you Glamp much and use the converter much, replace it with a proper 3- or 4-stage device. If you're boondocking, keep the batteries topped off with a small 3-stage charger while at home.
Happy trails from the Scourge of the ION.
