Old 06-13-2024, 07:51 PM   #1
2019 23' International
Phoenix , Arizona
Do we need new batteries?
2019 23CB international Serenity
Can someone help us determine if we need new batteries? Heres what our panel looks like. Weve been traveling all day and are boondocking.
Were on the road for the next 5 weeks and can buy new batteries if we need to. (Not lithium at this time)
Any help/suggestions?
Flynnsmom is offline   Reply With Quote
Old 06-13-2024, 08:33 PM   #2
19 Bambi Flying Cloud
BikeCamper's Avatar
2017 19' Flying Cloud
Airstream Coach - Other
Husqvarnia , Husqvarnia
Probably yes.
But more info needed. How old are these batteries (original?) What type of batteries are they? How are you charging them? How long has it been showing a voltage reading below 12V ?
2017 Bambi 19 Flying Cloud
BikeCamper is offline   Reply With Quote
Old 06-13-2024, 09:22 PM   #3
Phoenix , Arizona
More info added
Original batteries from 4/19. Marine and RV Delco Batteries.
We have solar panels. When were driving during the day, it shows 13 +\- V.
When we stop, it drops below 12v quickly.
This is the first time its happened.
Also, we live in Phoenix so the heat is hard on batteries.
Old 06-13-2024, 09:53 PM   #4
richard5933's Avatar
1994 25' Excella
Waukesha , Wisconsin
If the batteries are from 2019 then they are 5-6 years old (may have been made way before the Airstream). Replace them. Even if they can be made to take a charge, they gave you a long life for traditional batteries and I wouldn't trust them to perform well anymore.
It sounds like your charging system is getting the voltage up (can't tell from your post if it's the solar and/or the tow vehicle doing the charging, but no matter) but that the batteries are not taking the charge.
You could pull them and have them tested at a battery shop, but I wouldn't bother. If you're not ready for lithium yet just replace them with the best version of the same you can find/afford and carry on having a great time camping.
Richard
11018
1994 Excella 25 'Gertie' Follow the build on Gertie!
1999 Suburban LS 2500 w/7.4L V8 'Bert'
1974 GMC 4108a - Custom Coach Land Cruiser 'The Bus' (Sold)
richard5933 is online now   Reply With Quote
Old 06-14-2024, 03:30 PM   #5
2018 16' Sport
St. Louis , Missouri
Go to an auto parts store and they will test your batteries. Dropping below 12volt is usually a sign that you need batteries. Check out lion or Renogy lithium. Reasonable prices. Last batteries you will buy.
Sport 16 STL is offline   Reply With Quote
Old 06-14-2024, 08:01 PM   #6
2017 28' International
Jim Falls , Wisconsin
Caution: Your electrical components need to be lithium compatible.
Daquenzer is offline   Reply With Quote
Old 06-14-2024, 09:27 PM   #7
daleyocum's Avatar
2018 25' Flying Cloud
Portland , Oregon
Agreed. I wouldn’t switch to lithium on the road, it can be involved and turn into quite the rabbit hole. I’d get AGM batteries for now. What you are describing sounds like the batteries have reached the end of life. I’d do it sooner than later because at some point your jack won’t work and fridge won’t start. THAT would turn into an emergency,
daleyocum is offline   Reply With Quote
Do I need 4x6v Batteries to replace 2x12v Batteries? DaytonaDan Batteries, Univolts, Converters & Inverters 28 03-20-2020 09:43 PM
BATTERIES. 2 NEW Interstate Batteries kapt59 Airstream Classifieds 1 08-20-2018 08:13 AM
2 batteries outside and two batteries inside timmaah Electrical - Systems, Generators, Batteries & Solar 14 08-25-2011 07:18 AM
Batteries..All about batteries FrankR Batteries, Univolts, Converters & Inverters 0 07-17-2002 09:05 PM
