Old 01-24-2020, 06:52 AM   #1
2019 28' Flying Cloud
Dripping Springs , Texas
Do I need a temperature sensor?
I have 2x Trojan T105 batteries, planning on the Victron 712 bluetooth monitor.
Do I also need the temperature sensor? Can it indeed replace the stock power wire for the Victron? (ie. the temp sensor provides power and reads temp)
This
https://www.amazon.com/gp/product/B0...c=1&pldnSite=1
Kalashnikov is offline   Reply With Quote
Old 01-24-2020, 07:42 AM   #2
2018 25' International
Slidell , Louisiana
You don't need the temperature sensor, it's an option and no the sensor wires cannot serve as the power lead. there is a separate phone jack interface cable to the shunt or USB to the Color Control whichever you are planning to use.
Brian
Old 01-24-2020, 07:52 AM   #3
AirMiles's Avatar
2018 27' Globetrotter
Apollo Beach , Florida
This
The Victron Smart Battery Sense module provides temperature and voltage compensation for Victron SmartSolar charge controllers without a BMV-712. I use this with my 6V wet-cell golf cart batteries instead of a BMV-712. It works perfectly. I have mine mounted outside the metal battery box because the 3m version does not have a powerful enough signal to consistently work from inside the box. The new 10m version should work from inside the battery box. All you do is connect wires to the positive and negative battery posts, stick the module to a battery, and communication is wireless back to the Victron SmartSolar Controller mounted inside your Airstream. $39.10 https://www.amazon.com/Victron-Batte...07RTYGMBD?th=1
I believe the Victron Smart Battery Sense is incompatible with the BMV-712, probably because both would be attempting to provide temperature to the Victron SmartSolar Controller. If you want to have a BMV-712, then I would recommend buying the temperature sensor. With a BMV-712, you need to run a wire between the BMV-712's Shunt and the battery. Temperature compensation will help your batteries charge more efficiently in hot or cold weather, and will possibly increase battery lifespan by 20%. My batteries frequently are being charged with the battery box reaching 110 degrees here in Florida so I feel temperature compensation is required.
2021 Northern-Lite 10-2 & F350 DRW PSD, 600W Solar/Victron/600A BattleBorn
146 nights 31,000 miles (first 10 months!)
Sold: 2018 GT27Q, 74 nights 12,777 miles
Sold: 2017 FC25FB, 316 nights 40,150 miles
Sold: 2013 Casita SD17 89 nights 16,200 miles
AirMiles is offline   Reply With Quote
BMV-712 Battery Monitor Temperature Sensor billrector Batteries, Univolts, Converters & Inverters 2 12-18-2018 11:04 PM
Temperature sensor fix for A/C too cold billrector General Repair Forum 2 10-29-2018 03:31 PM
New MicroPulse Sensor and re-cal... post mortem on old sensor RFP General Repair Forum 10 10-25-2017 08:29 PM
Shorten temperature sensor wires Mgieselman Electrical - Systems, Generators, Batteries & Solar 2 10-27-2016 04:26 PM
Interior Temperature Sensor not Working Joohntooth Furnaces, Heaters, Fireplaces & Air Conditioning 0 05-31-2016 08:01 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
